I am going to get a second SAZ-3500d to power my (2)18" Fi BTLs. They are D1 and i am afraid i don't have the electrical to back them up strapped @ 1 ohm. So I was wondering what the output would be running 2 ohms per sub? My electrical will consist of a 300A alt, (4) Odyssey PC1500's, Optima Red top under the hood, big three in 1/0, and (3) runs of 1/0. This is a daily set up and i play it loud as often as i can.
'05 GMC Envoy
H/U: PIONEER AVH P4300DVD
Subs: (8) SA-12's
Amps: (2) SAZ3500d's
MECHMAN 270A Alt and 5 Batteries with lots of 1/0
You have batts you have a h/o alt you have the big3...what more do you need. Maybe a BIGGER alt but you should be able to push that setup pretty hard with what you have.
you just might not be able to beat down for very long!
or just run one. because you would lose output by using two in that fashon. If im correct you would only get 1500 watts out of that setup. Whereas you would get 1750 out of 1 at 2 ohms.
see what everyone else has to say but i say runem!
Edited by jvillefinest
2007 Acura TSX
Stock Navigation
Rockford 360.2 (FOR SALE)
Sundown SAZ3500
2 12" DC Sound Lab LvL4 @2ohm
JL 600/4
2 Sets of Focal 165K2P
My question is.... Should i run them at a 1 ohm mono load or a 4 ohm mono load (strapped)?
'05 GMC Envoy
Subs: (8) SA-12's
if you ran 2 ohms per sub, and wire it to the amp wouldnt that give you a 1 ohm load technically? I think you should be fine running it at 1 ohm personally with what you have just be easy on it
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
To get a 1 ohm load i would be running each amp at 0.5 ohm
'05 GMC Envoy
Subs: (8) SA-12's
Gotcha, i read everything except the 2nd amp part, im sorry :) dual alt setup time?
Team DC Audio
You would be wasting your time getting a second amp unless you ran them @ 0.5ohm each. Two amps @ 2ohm each will do the same as a single amp @ 1ohm. I'm not familiar with those exact batteries but it seems like you have a very good electrical setup. Depending on the specs of those batteries you should be able to play of saz-3500s @ 0.5ohm just fine.
With those batteries and alt it should produce somewhere around 502 Amps. Does that sound like that will suffice? I am not too sure on the draw of those amps @ 0.5ohm.
'05 GMC Envoy
Subs: (8) SA-12's
  • Who's Online   0 Members, 0 Anonymous, 1611 Guests (See full list)
