my t15004 all of a sudden started cutting out, i've ALWAYS been able to turn it really loud, my gains are set very low. all of a sudden last night, i cant turn it up more than maybe halfway the music cuts out, the sub amps stay on though. I have a 300 amp alternator from EA. my ford factory starter battery up front(kinetik 2000in the mail) and 3 kinetik 2400's in the back. I decided to just check the voltages because what the hell I never have, so as i was testing i realized. With engine RUNNING, every battery is only at 12.6?!?! with engine off, the starter battery is at 12.6 and the 3 kinetiks are at 12.8. also, i put the multimeter on the amp terminals and turned it up, the voltage only dropped to 12.4 and the amp shut off. what the hells going on. someone please help?!
play Moola.com its actually fun and free...
click here to join Money games!
its just games with free money!
Once on a T20001bd pieces of wire fell into it. (On the board, inside the amp) Started to cut out after a volume. So we opened it up and cleaned it. Only took 10-15 min. Problem solved. But it doesn't sound like thats the problem.. Your idle with car on should be more than 12.6.
If you have a multimeter I'd check your output voltage from your alt. It sounds like it may be taking a dump on you in a slow manner.
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
I had a similar problem with someone else's system. They had a Kinetic Battery up front and one in the back. I tested the voltage from the alt. and it was fine with the engine on, but when I tested the battery in the back it was around 12.4. The amp would shut off once I raised the volume to a certain level. I checked everything over and over again and still couldn't find anything wrong. So I decided to change the anl fuse up front and fortunately it solved the problem. The fuse looked like it was in perfect condition, but looks can be deceiving. Try this out. I hope it solves the problem.
BlockShaker's Competition Page and Build-Up Pics
MY SET UP:
Eclipse CD5435 CD/MP3 Player
Alpine DVE-5207 DVD Player
Alpine PKG-1000 10.2" Monitor
Alpine TUE-T151 TV Tuner
Boyo Back Up Camera
Alpine ERA-G320 EQ
Apple Mini Ipod
Scosche RF Wireless Remote for Ipod
Stinger Volt Meter
Audiocontrol MVC
Precision Power PCX-2400
Precision Power PCX-4125
MB Quart Premium PCE-215 (2 Sets)
MB Quart Premium 6 1/2" Mid-Bass
JL Audio 15W0-8 (8)
Stinger Battery Power2 SP1000 (2)
Stinger Fuse Blocks, Holders and Distribution
Alumapro 15 Farad Cap
Stinger 200Amp Relay
100 Blue LEDs (Headliner and Amp Rack)
Stinger Hyper RCAs
Stinger Wiring- 1/0 GA, 4 GA, 8 GA, 10 GA, 12 GA and 14 GA
5 Blue LED Toggle Switches
  • Who's Online   1 Member, 0 Anonymous, 1447 Guests (See full list)
