what about the power acoustik bamf 4000d
pioneer avh-p4200dvd (soon)
Highs amp Zx350.4, zx200.2
4 Kicker Cvx 15 D4
Sub amps (4) Zx1000.1 (need one more)
doors (6)kicker ks 650
Still under construction
not 4k rms but alot of people swear by them because they are cheap
i need 2 amps to push 4 CVX 15 DVC4 AND WHAT U THINK
4 Kicker Cvx 15 D4
that amp may be able to do half of rated, so 2 of those can probably push your cvx's...but you're getting a low quality amp nonetheless (i think it does ~1200 watts at 1ohm, like 1400 max or so,,,only 120a of fusing)
retail is like 500 almost, people buy em for 200ish online, why not just get 400 bux and get a aq2200 or a used 3500? both of which will give you more power, and it'll be cleaner to boot.
or even the amps i run, jbl gto1400, theyre about 80 bux more, but really do 1500wrms without breaking a sweat, and do it cleanly and efficiently
just keep in mind, the bamf is an ok 1200 watt@1ohm amp, dont let them trick you into thinking it does 1700rms or 4000max or whatever the literature says, its bullshit, and when you put it on an even plane of 1200ish watt amps, it starts to look like a real bad idea.
Team DC
that amp will give you about 1000rms at a perfect 14.4v.
PA amps = no good -
they are 4000watts wls - when lightning strikes
The REAL YouTube Page
●▬▬▬▬★▬▬^๑۩۩๑^▬▬★▬▬▬▬●
Head Unit - Pioneer DEH-p6000ub
Equalizer - Soon To Come
Amplifiers - (4) Soundstream TX1.2600d's
Subwoofers - (2) Soundstream XXX 18's
Enclosure - 16 Cubic Foot Wall Tuned to 38hz
Power Wire - (200ft) Tsunami 0 Gauge PRO
BIG 3 w/ 8 C&D Batteries
Team DBs (Driven By sound)
There is one line of PA worthy to buy if you see on clearance, or second hand, and thats the DB series. These are real amps, same board as a few other amps, and have been proven in the lanes for a pretty good price. But I think they may be a tad sensitive, as I had 3, 1 blew up instantly when hooked up, and the other, well, Iam replacing FETs on it now. But they do put alot of power out at 2ohm, and 1ohm
the one I have is the P3000DB, and was pushing 2- Kove Armageddon effortlessly
PA amps = no good -
they're decent amps. but its just that they dont put out as near the power as they advertise.
very little people bother to do the math on what amps can really do. (basically what i did)
yes sir i like my a3000db amps! for the price they are not bad at all i got them for 230 each and have two of them pushing my lvl 4's
vehicle-02 toyota celicawoofers-groundshaker g-s1 10" woofersamp-SUNDOWNAUDIO SAZ 3500battery-1 C&D battery
