installing an in dash dvd player
I am helping my friend install an in dash dvd player and everything works but when u try to play dvds it says shit about the parking brake or whatever. is there any way to wire both the parking brake and the reverse bulb wire so that you can play dvds while driving(not for the driver to watch but for the passengers.) we tried to install the wires to power and then to the remote turn on and the unit just says no signal detected. idk wtf to do. any suggestions would be greatly appreciated
if its a pinoeer the wire is a lite green in color. or what ever wire it says to put to ebrake.
what i did was grounded the wire with a switch in the middle i.e green wire from hu to switch to ground. pinoeer you have to switch twice. i use a rotry switch for a lamp. mounted under dash. two turns and presto i can watch while on the go
other way if you have it hook up the way its supost to be just click the parking brake one notch
this will turn off day time runnin lites on chevys
~2006 chrysler Sebring~
~2 runs of 1/0 front to back~
~1/0 wire for "big 3"~
4 spl-hx 12'' dual 2
2 dtr 1.3400
3 c&d terminologies 1000s
100 aH Each
piccso 6.5 comps
pinoeer avh 4900dvd
pioneer xm box
blue gauges
custom dave the box guys box
new stuff on the way
Team
Soundstream
pac makes a part that bypasses the parking brake wire and lets you see movies while driveing
The Shoe Maker without shoes!
the reverse signal line (usually purple) will switch the unit into "rear view mode" if it sees 12 volts. this is only if you have a reverse camera, if you dont just leave it disconnected for now. the parking brake wire is usually light green or pink (if you have an alpine, get a part called a ptr7 from peripheral, itll do the bypass for ya)>
read the manual...if it says you have to do some brake on brake off reverse thing (which im guessing...which means you have an alpine) get a ptr7
if it says it needs to see a parking brake on/off/on or parking brake on after ignition, put a switch in and flip it a few times till video shows
if it doesnt specify, just touch the brake wire to the radio chassis and turn the car on, if video plays just tie it in with the ground (black wire)
i assume no responsibility for anything happening while you watch the screen, or anything you do to it in the installation process, but that should be a given.
Team DC
grab a relay
wire it
85 to your remote turn on
30 to parking brake wire
87 and 86 to ground
watch tv
99 suburban, ranger rover headlights, SS front bumper,roll pan with frenched tag, 2nd row delete,glassed dash..audio to come whenever I figure out what I want.
For my Pioneer I just hooked up a toggle switch to the ebrake wire from the unit and it works fine
1990 Chevy Suburban (Big Booty Judy)
(4) Sundown Audio Zv5 18's
(1) Sundown Audio Salt 12K
(1) Sundown Audio SAX-100.4
(1) Sundown Audio SAE-50.4
(2) Crossfire ST-1 Tweeters
(2) Obsidian Audio ST-1 tweeters
(4) Sundown Audio Neo Pro v3 6.5's
Saving 2nd Bass
  • Who's Online   0 Members, 0 Anonymous, 1247 Guests (See full list)
