OBI Posted September 17, 2009 Report Posted September 17, 2009 Is it neccesary? I've seen Steve do it on his rebuild video, also seen that Van with the 12 18's do it. Is there a reason? Better conductivity? Asking cause I can get some Aluminum bars tomorrow for free, that I can use as buss bars. Also is there a certain type of aluminum that I have to use?
Boon Posted September 17, 2009 Report Posted September 17, 2009 Aluminium gets a very fine coat of oxide on the outside of it. It's probably worthwhile giving it a quick rub with some fine sandpaper just to be sure you have a good connection. 10.x volts fo' life!
bobonit Posted September 17, 2009 Report Posted September 17, 2009 x2. Just give it a good rub down with some fine grit to clean it off. Once you have your connections on, the parts of the bars that are still exposed will tarnish again, but don't worry about that unless you want them to look pretty. 97 Maxima SE Bunch of shit going in, check out the build Build Log
OBI Posted September 17, 2009 Author Report Posted September 17, 2009 Aluminium gets a very fine coat of oxide on the outside of it. It's probably worthwhile giving it a quick rub with some fine sandpaper just to be sure you have a good connection. x2. Just give it a good rub down with some fine grit to clean it off. Once you have your connections on, the parts of the bars that are still exposed will tarnish again, but don't worry about that unless you want them to look pretty. Thanks guys I thought there was a purpose to. Now it makes more sense.
lanman31337 Posted September 17, 2009 Report Posted September 17, 2009 Copper can sometimes get a little oxidation, or they might have a little grease on the outside of it. Give it a quick shine as well. 2 - Audiopipe AP30001Ds 1 - Lanzar Opti Scion 600.4 4 - Lanzar Optidrive 1232D's 1 - Lanzar Opti 5.1 1 - Lanzar Opti 6.1 1 - Lanzar Opti 6C midbass 1 - Alphasonic PCT6551 1 - Lanzar VX830 1 - JBL 22 band EQ 1 - Lanzar SDBT75NU 1 - AudioControl Epic160
