AlpineGuy87 Posted April 18, 2007 Report Posted April 18, 2007 Make a hole then get a little grommet to go around the rough edge of the metal. Then just run your wire through. exactly!! Quote 06 SCION tC
dleccord Posted April 18, 2007 Report Posted April 18, 2007 sometimes you have to pull the carpet back a little and find one. if not, at night, use a flash light and get under the dash compartment and see if revealed holes. Quote refs: chode69, superduper
Slinky Posted April 18, 2007 Report Posted April 18, 2007 i use the flashlight technique too. there is always a stock grommet there. you just have to dig for it. if you cant it from the inside, jack up your truck and take off your front left wheel and under the wheel well plastic, you will find the other side of the grommet. Quote DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
