Great stuff! That is like 100x better than my first 3 systems! :)
How are you wiring the mids again? If you have each amp wired to be bridged mono, you can do a "Y" rca out of your head unit to each amp making a left amp and right amp (or front and back... what have you)- that way you still have imaging. ....or not. Just an idea if you were worried about imaging in your shop. :D
Looks Good!
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
Thanks guys. I forgot to mention im going to be using 8 of the 10 speakers I picked up, just for wiring purposes (a pair in each corner of the shop)
And I will be bridging the 4-channels to just basically have a right and a left in the shop...just the same 2 channels of rca's through all of the amps atleast until I find my 7700..im using that really old model right now and only has a pair of pre-outs :(
Edited by Pioneer~Saturn
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
Thanks guys. And yea, it's in a storage unit that has minimal power but the owner is allowing me to upgrade the electrical in there and eventually a couple more 20 amp circuits will be in there and possibly a 40 amp circuit to have all the juice I need :)
I just got 4 shop lights that will be more than enough to light the place up and all I really need is an air cleaner/circulator and the dust collector tubing setup to turn on with the table saw etc. to collect the dust...once winter rolls around it wont be too pleasant sealed up in there without that.
Hopefully this will be up and running at some point this week
Team Tupperware
