drewb53 Posted September 24, 2009 Report Posted September 24, 2009 is the AQ1200D 2 ohm mono or is it 2 ohm stereo? 2003 Chevy Blazerkenwood headunit4 ga. kicker wiringAQ1200D amp2 12" DC LVL 3'sStinger Volt MeterMy Build LogBlazer is no longer. Totaled 02/14/2012 no. this is for converting dc to ac. useful if you want to run a blender inside your car.
dmanson Posted September 24, 2009 Report Posted September 24, 2009 is the AQ1200D 2 ohm mono or is it 2 ohm stereo? it's 1 ohm mono and 2 ohm in stereo 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
drewb53 Posted September 24, 2009 Author Report Posted September 24, 2009 kinda noob question but for the right wattage it needs to be wired in 2 ohm... is stereo okay or no? 2003 Chevy Blazerkenwood headunit4 ga. kicker wiringAQ1200D amp2 12" DC LVL 3'sStinger Volt MeterMy Build LogBlazer is no longer. Totaled 02/14/2012 no. this is for converting dc to ac. useful if you want to run a blender inside your car.
Boon Posted September 24, 2009 Report Posted September 24, 2009 Uh wtf. How do you plan to wire a AQ1200D in stereo, it's a monoblock amp. 1 channel. Mon-o. 10.x volts fo' life!
drewb53 Posted September 24, 2009 Author Report Posted September 24, 2009 well from what i had found out above is that it was stereo in 2 ohm i thought it would be mono but hell i dont know? and sorry this is really only the 2nd amp i have bought. 2003 Chevy Blazerkenwood headunit4 ga. kicker wiringAQ1200D amp2 12" DC LVL 3'sStinger Volt MeterMy Build LogBlazer is no longer. Totaled 02/14/2012 no. this is for converting dc to ac. useful if you want to run a blender inside your car.
finkster Posted September 25, 2009 Report Posted September 25, 2009 Uh wtf. How do you plan to wire a AQ1200D in stereo, it's a monoblock amp. 1 channel. Mon-o. haha x 2 DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
