what would be a good amp for the dd9515 with dual 2's. i want to wire it to 1 ohm, and it will be daily use. box is 3.5cu at 36hz.
2004 explorer xlt
HU: Alpine iva-w505
mids/highs: stock
Sub amp: american bass vfl200.1
Sub: dd9515
refs: t-roy
k, one thing i forgot to add. i just got it back from a recone. how easy should i be on her till she breaks in?
2004 explorer xlt
HU: Alpine iva-w505
mids/highs: stock
Sub: dd9515
refs: t-roy
get in on the rd 3250.1v2 presale. that would be perfect for that sub.
Need any thing chromed? Hit me up!!!
gamer tag: (360)
mEmEnToMoRi64
My Myspace
refs:
from here: RollinSoLow, Derrick824, Ray
from c.a.c.o. : teamsubgopoof, splvictim20, SundownAudioNY
from C.A.J. : Donpisto, spladdict19, CAJunkyard, JBLCAMRY, DasBot (robot underground)
from ca.com: alxmlr789,photocrazy8
as dd says, play it easy for a bit til it breaks in. the 9500 series are super stiff subs. so just be a little easy on it for a week or so.
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
2 batcap 4000's 1 batcap 2000
dual alts.
154@37hz and climbing
http://www.cardomain.com/ride/3231683
http://www.myspace.com/torque150
It's a 95! Smash the shit out of it! We 4kw burped a 9510 half an hour after reconing it. That's a quick way to 'wear it in'
But seriously. Be kinda gentle for a little while. You can tell a big difference just pushing on the cone, you'll know when it's 'ready'.
10.x volts fo' life!
DAT 2500.1, SounDigital 3000.1, AQ 3500D, Sundown SAZ-3000D, Audiopipe A3000D, etc... Many amps out there that will fit your needs, all depends on what you're trying to spend.
Btw do you have the electrical to back up 3k+ daily??
Pioneer AVIC-N2
I got the M3 on my 9515G and it beats the shit out of it and it aint even turned up make sure you have some batterys or u will clip it and bottom your sub out... i did that alot :(
- 1998 Ford Mustang -
Time to rebuild.
4 15s and alot of power
TEAM DTF
