9515ROB Posted September 29, 2009 Report Posted September 29, 2009 I have a DD M3 and i was wondering what kind of power you are putting on it so far i have my stock battery under the hood a 1800 kinetik in the trunk and another 1800 on the way and im hopefully buying a 220 amp alternator tonight. I plan on getting a 1800 under the hood some time soon if i can get the right price. Do you think this is enough power to keep that amp from clipping or should i get more batterys Quote - 1998 Ford Mustang - Time to rebuild. 4 15s and alot of power TEAM DTF
AI James Posted September 29, 2009 Report Posted September 29, 2009 should be more then enough for an amp that does roughly 2400rms Quote
9515ROB Posted September 29, 2009 Author Report Posted September 29, 2009 okay good bc if that didnt do it idk what would Quote - 1998 Ford Mustang - Time to rebuild. 4 15s and alot of power TEAM DTF
Boon Posted September 29, 2009 Report Posted September 29, 2009 I'm told (haven't used one myself mind you) that they work surprisingly well even when your voltage is pretty shithouse. Quote 10.x volts fo' life!
9515ROB Posted September 30, 2009 Author Report Posted September 30, 2009 they work well but it clips like a son of a bitch and bottom out my sub on low voltes on certain lows Quote - 1998 Ford Mustang - Time to rebuild. 4 15s and alot of power TEAM DTF
loburbon Posted October 3, 2009 Report Posted October 3, 2009 the m3 is the only amp i use. and if your bottoming out on certain low notes, tuning is your issue not power. the last one i clamped was wired to .5 with a rise to 1.5 and it did 2400-2500rms from 30hz all the way to 55hz. and it put out those numbers at 11.9v. those tests were done on 2 redtops and a single kinetik 2400 and a stock 2000 blazer alt. Quote 2000 gmc yukon 4 sundown Zv3 15's 4 dd m2a's kenwood kdc-x994 2 batcap 4000's 1 batcap 2000 dual alts. 154@37hz and climbing http://www.cardomain.com/ride/3231683 http://www.myspace.com/torque150
Marlo Stanfield Posted October 3, 2009 Report Posted October 3, 2009 That will be more than enough electrical for that amp... I used to have one, but sold it locally. Had mine wired to .7 ohms and after rise it was @ 1.6 ohms and i got just under 2300 watts clamped. Don't remember my exact voltage but I'm pretty sure if was in the low 13s/high 12s. Quote 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
steven Posted October 4, 2009 Report Posted October 4, 2009 I ran one for a long with no problems with without a HO alternator just had 1 optima yellow top and 1 hc 1800. Quote
