aluminum 26.5 ||| aluminum oxide (14 ℃) 1 × 1014
brass 64 ||| aluminum oxide (300 ℃) 3 × 1011
chromium 126 ||| aluminum oxide (800 ℃) 4 × 106
copper 17.1 ||| carbon, amorphous 0.35
gold 22.1 ||| carbon, diamond 2.7
iron 96.1 ||| carbon, graphite 650 × 10−9
lead 208 ||| germanium 0.46
lithium 92.8 ||| pyrex 7740 40,000
mercury (0 ℃) 941 ||| quartz 75 × 1016
manganese 1440 ||| silicon 640
nichrome 1500 ||| silicon dioxide (20 ℃) 1 × 1013
nickel 69.3 ||| silicon dioxide (600 ℃) 70,000
palladium 105.4 ||| silicon dioxide (1300 ℃) 0.004
platinum 105 ||| water, liquid (0 ℃) 861,900
plutonium 1414 ||| water, liquid (25 ℃) 181,800
silver 15.9 ||| water, liquid (100 ℃) 12,740
solder 150
steel, plain 180
steel, stainless 720
tantalum 131
tin (0 ℃) 115
titanium (0 ℃) 390
tungsten 52.8
uranium (0 ℃) 280
zinc 59
Edited by lanman31337
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
technically the best grounds are the bolts that actually ground the alt. like stated above thats the point of the big 3 is to reduce resistance with the grounds.
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
For SPL, if I'm shifting 1000A the length of the car and I can get 0.001 ohms less... that's still 1V (!!!!!!) at the end of the day which is probably worth at least 500w to me.
Daily, meh. Upgrade the battery -> chassis ground and ground it properly in the back and you'll be sweet.
10.x volts fo' life!
lots of good replies here. Thanks fellas. Ill get a chassis reading when i go over to my friends house either tomorrow or Thursday.
I think this topic cleared up a lot of talk about grounds in general.
Eclipse cd7000
Don't bother trying to get a reading unless your multimeter says Fluke or similar on it and cost upwards of $1000.
It'll just say 0. Or the resistance of your probes.
There are special ohmmeters out there for reading the difference between 0.001 and 0.002 ohms but the better way IMO is to use a good clamp meter and a good volt meter and shift some serious current through it then measure the drop :)
