Crump Posted September 29, 2009 Report Posted September 29, 2009 I have a trunk car heres the equipment 1 12" Fi Bl 1-Rockford Fosgate T-1500-1bd Optima up front Kinetik 1800 in back Ill have my rear seats down. What else should I do, I hit 142.1 @ about 39 htz ON MUSIC with both doors open on a 60 second run. So I have time to do a couple things. Give me some examples Passenger seat down Unplug m 4 channel= more power for sub amp and burp it.. Help me out these tenths can make me or break me as some of you surley know Heres a link to my run http://www.stevemeadedesigns.com/board/ind...showtopic=56459 Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs
basshead4life Posted September 29, 2009 Report Posted September 29, 2009 if you leave the passenger door shut and open just driver door with mic on passenger side it should be louder. EDIT: spelling Team S.M.D. Maritime Car Audio- (2) 18" SSA ZCON D1 - American Bass 500.1 - 60 ft of 3/0 -480 Ah of battery - (2) stock alternators (70 +90) - Kenwood Excelon x-794, 4v preouts car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
Loudcav Posted September 29, 2009 Report Posted September 29, 2009 close the passenger door should be worth a good bit
Rogers Posted September 29, 2009 Report Posted September 29, 2009 x2 driver door open.... passenger door shut with window up... i gained 3db by doing this in an outlaw run a few years back... but since ive learned to just put the mic in the port...lol... http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
fischy fisch Posted September 29, 2009 Report Posted September 29, 2009 have you ever try fliping your box around if you can turn off your ac or turn on your ac try that and see if it does anything edit: if you can i depending on the class idk the rule but have people stand in your door way lol. but i haven't and i don't plan on it. plus i'd probably miss and hit her belly button or her ear or something. lol.
Crump Posted September 29, 2009 Author Report Posted September 29, 2009 All good suggestions, but what about "unplugging" my 4 channel will that allow more power to go to the sub amp or will the sub amp pull the same? I will have all other electronics off in my car other than my ipod, but i may make a cd with the tones if I want and then play some music. and what about driver side open, rear seats and driver seat down? And If i hit 142.1 on music what will the difference be with a tone,I know there isnt a specific # cuz every car is different, but can I expect a 1/2 db or a full db? And should I turn my gain on my amp up a little, its only a 60 second run, and Its at 1 out of the 11 thats on the T-1500-1bd. I know the guy that beat me was running 3/4 gain and 1/2 ohmload @ the amp. EDIT: Thanks in advance for your help ill be back in roughly 5 hrs (4 pm here, be back at 9) Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs
