What kind of metal?
Tomorrow i get 50 feet of some 1/0 and ill be doing the big 3 and 1 run of 1/0 for now. What kind of bolts do i need to fasten the wire down to the frame? Also do i need washers? I also have a optima red top battery. How can i use the side post(what length/size bolt)?
My 02 Accord Wall Build
2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500
Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s
Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters
DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
Your general average zinc plated will be fine. 3/8 inch x how ever long you need. Washers top and bottom would be good. I'm not sure about the optima posts.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
any bolt would work.....use washers and a lock washer to keep it tight, and remember to polish that metal!!! and for your battery, long enough to attach all your terminals, but not soo long that you need a dozen washers to tighten it? Stick a pencil in the side post to measure your depth, then add the width of all your terminals and washers.......and Im not sure as to the size of hole in the optima's, but you gotta have something around there to test for the thread pitch and size.....
06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck)
7" BDS HC lift kit
(5) 37x13.5R18 Toyo Open Country M/Ts
(5) 18x10 Moto Metal MO962
tablet in lieu of deck
blue tooth interconnect to soundstream eq (for volume control and bass control)
4 Alpine type r 10's
6 cubes net, 80sqin's port, tuned to 33hz
2 brutus brx5000.5's
2 pairs 3" polk audio for a pillars
4 pairs polk audio 6.5 comps
1 pair 8" polk audio for mids
2 xspower d3400 batteries
.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!
P.S. Thanks Steve....for the demo!!!! loud as fauk!
if nobody posts it prior, i'll check at work today, i've got a thread gauge and we sell optima batteries so i'll check it for you.
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
well to me it looks like no one can answer that because well its your car you are gona find out if u need washers or not and as far as using the side post all u need is the bolt that goes on it (which u can get at autozone)and a ring terminal oh and the bolts to use to fasten down to the frame..well i think any really.. i might be wrong but i used a bolt from ace hardware and it works fine.
  • Who's Online   0 Members, 0 Anonymous, 1452 Guests (See full list)
