Measure 3 times cut once. i threw a box together earlier and messed up a few times because i was in a hurry. take your time, dont rush! ;)
<u>99 Jimmy SLT 4WD</u>
Systemless.
<u>99 Grand Prix GTP</u>
DC XL 12 on 1.5k tuned lowwwwww.
I haven't used screws in a couple years now... I switched over to a nail gun like 3+ years ago and haven't looked back. As long as u use good quality glue, for the most part screws/nails aren't even really needed.
true that. just to hold the wood together while it dries
get someone else to help you. its always better to have two people doing it, in case you need them to hold the wood while you predrill or something. also i've been gluing the wood together, let it sit for like 15-20 mins (since wood glue dries pretty damn fast), and then i predrill and drill screws in later.
why?? why let the glue dry THEN screw it together? that's counter productive. glue, then screw while the glue is wet. makes a TIGHT hold while the glue dries. screwing after the glue is dry is not necessary
also if you use enough glue you'll already be air tight ;) but i always silicone it on the inside really good just to be safe anyways.
Thanks for all the help guys...
Here's my pregress so far...
http://www.stevemeadedesigns.com/board/ind...55608&st=20
2011 Dodge Durango Citadel AWD HEMI - LOADED
Stereo:  STOCK
Emergency Equipment:  Morotola - Federal Signal - Feniex - Gamber Johnson
Performance:  MOPAR Performance - Diablo
911 Calltaker / Diaptcher, Volunteer Ambulance Driver, Rescue Tech, Fire Fighter, Fire Policeman, Emergency Equipment Installer / Repairman
  • Who's Online   0 Members, 0 Anonymous, 2499 Guests (See full list)
