ok well i got my knu kandy 1/0 guage kit hooked up an just replaced all the speaker wiring on the subs with 8 guage wire an it got louder but now the problem is is when i turn it up to loud like when the subs are wanging hard it just shuts off ne one kno why that might be
Edited by Austin175
kia spectra 4 door
HU-a kenwood kdc-692x
optima red top under the hood ( kinetik battery or powermaster in the back )
Iraggi 260amp H/O alternator
1 set of knu kandy 1/0 guage wiring kit ( 2 more sets coming )
front speakers -
back speakers -
2 12" lv 4's with lvl 5 softparts ( going to be 4 in near future)
Sundown 3500d( going to be 2 sometime )
i have boughten from - Bass14(smd), ddbump(caraudioclassifieds)
You could be haveing to much of a voltage drop on your batt and your amp goes in protect
'04 Ford Explorer
Jenson headunit
Rockford Fosgate Power T-1000-4
Rockford Fosgate T-1000-1bd
2 Fi 15" ssds
4 Pioneer TS-D6802R
well it goes from 14 an looks what like is 13 or 12 volts when full tilt an my ground is on super tight but could the wiring on the inside the subs cause it also
kia spectra 4 door
front speakers -
back speakers -
Yes. I see in your sig your subs are dual 1ohm. If you accidentally rewired them in parallel/parallel instead of series/parallel then you are running @ 1/4 ohm which is WAY too hot for your amp.
yea that could very well be the problem
'04 Ford Explorer
Jenson headunit
2 Fi 15" ssds
4 Pioneer TS-D6802R
well i think that is my problem is the wiring on the inside the subs but if my ohm load is 1/4 then y is my amp not getting hot it dont even get warm at all
kia spectra 4 door
front speakers -
back speakers -
if you have a sub wired that low, usually amps will shut off almost right away to prevent damage
edit: the only way to see what the problem is is to check the wiring on the subs
Edited by Krannyman92
Having too low of an ohm load when the volume is down isnt going to make the amp too hot. Of course when you turn it up its going to get warmer. It may not even be thermal.....check your wiring inside the box and get back to us.
Eclipse cd7000
i will were going to take them out an re wire them to what the12volt.com says an see if that works an if it dont then im lost bc i have knu candy 1/0 guage wiring kit i have stunami(spelling) rca's an db links 8 gauge comp speaker wires no no wal mart or low budget stuff
kia spectra 4 door
front speakers -
back speakers -
  • Who's Online   0 Members, 0 Anonymous, 1006 Guests (See full list)
