You read that right, I'm doing the big 4! My alt is attached to the engine block through the bracket andthe bracket is tiny and has almost no surface area. So I'm going to upgrade that while I'm at it. So I'm basically doing:
Alt + to Batt +
Alt - to engine block -
Engine block - to Batt -
Batt - to chassis -
I'm going with some Knukonceptz wire because it's not too expensive. After everything is connected, I should use 10 feet of + and 15 feet of - (not too bad, considering the wire I'm going with is 1.75 per foot).
But I need some good lugs that won't cost me too much. Color doesn't matter. I have an Optima and 2 top post connectors for it, so I need... Ummm... about 5 or 6 connectors. Where can I get some? Can someone please post a link?
Thanks in advance.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
If you are ordering wire from knukonceptz why wouldn't you just order ring terminals from there too?
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
They have ring terminals?...
I can't find them. Gotta link?
In a way, I feel like an idiot.
Edited by 1992Chevy K1500
15.4" widescreen
What it does:
just go from the alt to the battery and frame no need to go alt to the block.
I'm not sure how well the block is connected to the frame. I want a solid connection. I'll check it out before I order, though.
15.4" widescreen
What it does:
Found the terminals. My computer wasn't showing several of the links, the one with the terminals was one of them. Thanks for the help.
15.4" widescreen
What it does:
the alternator makes the power for your electrical not your block.
if your going to your alternator for the ground no need to go to the block
Tibs 99 F-150 Build 8 twelves
8 - Re SE 12"s
2 - SunDown Audio Saz-3000d's
1 - vx4004 planet audio amp
big 3 1/0 gauge
MECHMAN 250 amp alt
MySpace
So even if I replace the wire instead of complimenting it, my connection will be good enough? Like I said, I just want the best possible connection.
15.4" widescreen
What it does:
Go from alt casing or bracket to frame and from batt - to that same exact spot on the frame should be sufficient. I have a 95 k1500 and thats how mine is.
Ok then. Should be similar since I have a 1992 K1500 myself. I'm going from the casing for the best connection. Thanks for the advice guys.
15.4" widescreen
What it does:
  • Who's Online   1 Member, 0 Anonymous, 1186 Guests (See full list)
