Is this a good amp? Kole KX1 5500D
barros57
i was going to get one of these for my 18" lvl4 but got the DC 1k instead just try it on your orion and see how it does
Refs-(b.f.) 99vic, WCA Rusty(x3) Nathan@XSPOWER, Ampjunkielikeme, Bread0710, AmiCreations (s.t.) REsLaPz, PandaGT(x2), Keiferacing, Juicemane (t.w.) Powski, Big gil[/center]
Build Log
http://www.stevemeadedesigns.com/board/topic/77726-sss-celica-dc-buildupdate-611-finished/
2005 subi STi 380whp 355whp
17" gold bbs
5% tint all around w/sunglare strip
JVC dvd double din
Knuconceptz 4ga wiring
XS Power!
Big 3
8" SAv2 d2
1800 audiopipe
how about you show a picture of a rockford fosgate 3000 watt amp, since that is what the kole is rated at.
the amp will work alright.
set the amp to 1500rms and it should be able to handle that alright.
let us know ow it performs.
oh, and you said you got it cheap. how cheap? if you got a 1500rms amp for 100-150 bucks, then kudos to you
8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee :DClick to see J00bles' Youtube Channel
Not to be an ass, but I doubt it. At 70% efficiency at 13.8 volts, it'll do about 1400 RMS or so. I'd set it at 1K even for the best result.
15.4" widescreen
128MB shared video memory
Windows 7 Home Premium 64 bit
What it does:
On a USB 2.0 Wireless card
How would i know it is set @ 1000 RMS? Would it be bad for the orion to underpower it? So you guys dont think I could blow this sub with this amp?
I think the orion 10" hcca is 1500 RMS
My 93 chevy truck Orion HCCA 15's Build
6K HID's
2 orion HCCA 15.4
2 AP30001D's
2 optima yellowtops, 2 C&D 270fr's, all 3 tsunami 1/0, CS144 190 amp
Rockford p200-2
Rockford p200-2
Rockford p300-1
Kole KX1 5500D -broken
I dont know, has anyone actually had this amp or compared it to others? Im seeing alot of good reviews on other sites.
Posted Image
Posted Image
6K HID's
2 orion HCCA 15.4
2 AP30001D's
Rockford p200-2
Rockford p200-2
Rockford p300-1
Im seeing about equal numbers of caps, transistors, power supply winding.... I dont know. I paid 300$ for the sub and the amp. So, about $150 VS $1849.99. Anyone who knows amps, any imput?
6K HID's
2 orion HCCA 15.4
2 AP30001D's
Rockford p200-2
Rockford p200-2
Rockford p300-1
But I think most of the reviews are by people that havent had many amps before or the ones that just upgraded from there Sony Amps, sure it may be louder than the sony but they arent gonna know they are not getting all the power advertised, they probably dont know that 150 amps of fusing means the amp does no where near rated, and all the other factors, they just see that it says 5500max and thinks thats a bigger number than what my current amp is, also most the people that review this amp have never dropped 1200-1600 on a true 4000rms amp.
And about the internals, just because they have the same amount doesnt mean that they are the same quality, or designed to make a true 4000rms. The parts in the true 4000k amps are built much stronger. One example is SoundDigital they have less Fets than an amp of equal power and the fets may look exactly the same, but internally the fet is built up more than the counterpart giving it the amp the ability to be smaller by using less parts, but the parts being much stronger.
¿ǝɯɐƃ ǝɥʇ
law of physics buddy
if it cant draw more than 150a (maybe 155a before poppin) then u wont have any more than that X ur voltage
150*14.4v = 2160... and thats a 100% efficient amp... which doesnt exist
so
2160*80% efficiency (average of most amps at 4ohms mind u!) = 1728watts and that is pushing the amplifier at max capabilities
so add in voltage drop and real world 1-2ohm operation
150*13.5v = 2025
2025*70% (closer to 1 ohm operation) = 1417watts
so 1300-1700 watts is what that can do at 1ohm
so their power ratings are max, and overrated
so
150*13.5v = 2025
x2
Build Log
17" gold bbs
JVC dvd double din
XS Power!
Big 3
8" SAv2 d2
1800 audiopipe
so
150*13.5v = 2025
So basically, if you don't have a Oscope, just pick a wattage under 1300 and set it with a DMM, right? (Just wanna be sure).
15.4" widescreen
What it does:
  • Who's Online   0 Members, 0 Anonymous, 2089 Guests (See full list)
