i used go dj by lil wayne last time i metered my car and it seemed to like it, was the loudest song i used. i need to seal mine from the trunk when i put mine in, but i dont wanna use great stuff and make it look all ghetto so i gotta find another way
1997 Pontiac Bonneville Black on Black on Black
15" DC Sound Labs Level 5 w/ quad coil in a T-Line tuned to 35 hz
7" Jensen VM9311TS Touch Screen Flip Out w/ J-Link
Blue Custom Trim
Blue Custom Fiberglass Rear Speaker Pods
Autotek Mean Machine MM2000.1
1/0 Knukonceptz KLMX
Rockford Fosgate Twisted RCA's
2 Audiopipe Anl fuse holders w/ 200A Kicker fuses
2nd battery (Soon to be an Odyssey D3100)
Dynamat Extreme Bulk Pack
Custom False Floor
15% Tint All Around
Custom Painted Stock Rims
My Build Log
Tailights
15" Lvl 5 DC T-Line Build
Im not using spray foam either. Im using closed cell foam tubes. Stuff you see at home depot for wrapping water lines. Cut it to length and shove it in the cracks with a stick and seal up the holes. I dont want to use great stuff yet because I have a feeling Im going to build a new box for it this summer. Even then I will probably just make it a litter wider so it will fit the opening better than it is now. There is a good 1" + gap on the sides but its hard to see because if the trunk covering.
ah ok, i knew you werent using spray cuz i saw you saying you were using foam strips, but alright i might need to try that. i think my box will be the last one i build for a while so i might be able to seal a little better, but if your new one is anything like this, then i cant wait to see the new one!
Blue Custom Trim
Custom False Floor
15% Tint All Around
My Build Log
Tailights
Looks really nice, what a cool gift
Lunar Amplifiers: L1500's x 8, L2125, L100X2, L55x2, L40x2 (2)
Digital Designs 9518G x 2
DDA-W 6.5 components
DDCX 4 x 4
DDCX 5x7 x 4
Iraggi Amputator 260
that's some good stuff right there! you like the results?
and that box is sick!!!!!!!!!!!!!!
So far we couldn't be happier. It slams hard.
The only things we need to work on are the electrical and the amp. I have the amp wired down to 1ohm and its a 2ohm stable class D amp. We have been running it for weeks that way and being careful with the volume knob, so far so good. I would feel better is it wasn't all running off a stock alternator, 90 amps, one Excide AGM up front and the 3 BatCap 800's in the trunk. When the system starts hitting hard the voltage starts dipping into the 12.3 - 12.6 range. Definitely need a HO alt and some bigger batteries in the back and then later an amp that's 3000 watts and 1ohm stable.
  • 1 year later...
i hate how easy you make glassing look
R.I.P!
(Nov-29-2009)
92 explorer
current build
