I have a question on what is the difference between a red top batt and a yellow top batt.
Edited by jrplayer35
jrplayer36
the red top is better suited for starting a car over and over again
the yellow top is better at holding a deep reserve of power best for car audio
I do have a system in my truck so should i replace my stock with a red or yellow top.
jrplayer36
Red top is a starting battery, has the fastest discharge and recharge rate of any optima battery. Discharge the battery below 10.5v more than 15 times and the battery will become a paper weight, is not designed to be quickly discharged all at once so your system shouldn't exceed ~2000 watts. = good for audio systems when the engine is running
Yellow top is a deep cycle battery designed to be drained to low voltages again and gain without damaging the battery = good if you play your system with then engine off and if you are running more than 2000 watts
But then again there are many other battery choices depending on what kind of system you wanna run and what kind of weather you live in
Edited by eliassami5
91' Jeep Cherokee - The Heep
Just Empty Every Pocket
96' Volvo 960 - The B◘x
[sPL_4_U]
HiFonics - Alpine
Pioneer - Clarion
Infinity - Kicker
KnuKonceptz
i have a red top as starter and yellow in the back,it does pretty good.
RE se xxx 18d2 (4)
Audioque 2200 (2)
DC Power 270XP blue
3 C&D fr310
Stinger wiring
CDT components
depends, what size batt can u fit under ur hood... and will that be the only bat u have on a stock alt?
Yes that will be the only battery i have on a stock alt.
jrplayer36
If your buying a optima new, your best idea is to not buy optima at all.
Go straight for a powermaster battery that will fit your car.
www.4xspower.com
I take it you dont like the optima batt.
jrplayer36
