Hey guys, my two 8's in a ported box on a ZX 300.1 Kicker Amp have been making this horrible noise it almost sounds like a fart, is the best way i can describe it. The box is right behind my seat in my 1990 Chevy. Ideas on how this problem was caused and how i can resolve it and is it serious?
-Jacob
If its a single cab, sub might be rubbing against something.
yea its a single cab, the seat is right up against the box and the subs i put some grills over the subs but it didn't help, same farting sound.
First thing that came to mind.
Pioneer AVIC-N2
i guess if it was rubbing against something the only thing would be the seat, and like i said, i put grills over the subs to keep it off the seat and it didn't make a difference.
Pull the seat fowards and see if you get the same sound
yea i tried that as well, didn't help, same sound...could this be a port problem? or is something wrong with the sub?
If you have a ported box place a hand over the ports and see if that stops it, if not pull the grills and lightly tug on the surrounds to see if they have broke free from the basket.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
thanks for the help but, just tried both those suggestions and neither worked :( the surrounds are still secure in place and putting my hand over the port doesn't make a difference, the horrible sound still exists...
Pull the subs and check the spiders or anything inside the box itself that could cause anything wierd.
Like a plastic bag that may have been sucked in or something.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
  • Who's Online   0 Members, 0 Anonymous, 2583 Guests (See full list)
