Yeah it's a 15. Those dimensions are my max ones. Might be able to do 18 or even 19 in depth but cant for length & height. What I really want to do is sell this off and get (3) 10s. FML.
:ph34r:
Edited by k3n12ock
First quesion that should have been asked - How are you not pleased with it? Lacking SQ? Crap output? Limited frequency response?
It's like going to the doctor and just saying "I'm in pain" and expecting a detailed diagnosis.
Don't leap into a new box until you work out what was wrong with this one. Chances are 5hz difference in tuning won't change much for you.
10.x volts fo' life!
for 1 6" aero
35w*16.5h*17d
3.995cuft
total length including flare is 14" (mounted on the outside of the box, u need at minimum 3" of clearance for a 6" port at the rear wall, so unless u turn it it can only be 14"... the extra volume should help with lows and make it more efficient off less power)
tuned to ~33hz
Boon and Decaf, sub seems to not hit some notes. I can't explain really. I was using an ap15001 but I've since sold that and bought a Sundown sae1200d which should be here on Wednesday. I guess it's just me not tuning the amp right and I want louder! Need more cone!
come on bro, which notes tho
lows mid highs, did it sound stressed/overworked
i mean if u set ur subsonic to high u would lose lows and setting low pass filter to low would cut off highs
ive seen this alot
using bass boost instead of more gain can do this since the boost is centered at a certain frequency so theres more boost at some notes than others
lots of things can do this, hopefully with the new amp and some help it would sound great
and andy (aka amatt85), if ur calc still works/is accurate that is what i still use... so that makes sense
i sure as shit hope it still works...lol...spent a lot of time on it..
and also, what kind of music are you listening to?
i likes me some audio stuff...
Jeezy - Put on
http://www.youtube.com/watch?v=9bHUE41uZlM
Since embedding is disabled.
The note at :53-:54. Not sure what the frequency and notes around there. They all seem very low and doesn't hit hard.
I listen to 90% rap. 10% other.
Jeezy - Hypnotize
Notes @ :33, :52 etc dont hit at all, it's like the sub doesn't even move.
Edited by k3n12ock
