its alot easyer useing a maxxlink than tryin to do it the old faction way with a dmm checkin voltage, just hookd rcas in, set to slave i think n then on u go
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>" type="application/x-shockwave-flash" width="425" height="350">
hope this helps
For sure Thanks for your help and input..
Too bad each amp will only be at 2ohm decreasing your output to ~600wrms per amp so ~12000wrms to each sub with two amps where as one could do the same work....lol
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
lots o power.
but really, just use two amps... easier.
4 amps at 2 ohms will give you more power and less strain on the amps and your electrical than 2 at 1 ohm. Much more efficient.
And jesus-titty-fucking-christ tacomabanga, n n n n n n n, call me OCD but it drives me fucking crazy, the A and D keys are what, 4 inches away? Then maybe your post doesn't read like a 12 year old wrote it? aghhhhhhh!!!!!!!!!!!!!!!!!!!!!!!! Ok rant over...
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 3008 Guests (See full list)
