I have an ARC 1500dr I got from a friend, and it has 2 gauge inputs. They require spades, unlike more modern ones that you can just put the wire straight in. I can't seem to find any fork spades for wire thicker than 4 gauge.
Does anyone make this?
If not, what do you guys do to connect amps like this with thicker wire?
Old setup
2002 Camry LE
Fi Q 12" BP power in a 2.3 cu box tuned to 28 hz
Alpine MRP-1000
JVC Deck
RE 800.2 speaker amp
RE Coax 6x9's in front doors and Deck
Alpine Type S 6.5's in trunk
now...
2006 Subaru Legacy 2.5i Special Edition
JVC KDX double din
1 Run of Knu Konceptz 1/0
Big 3
Waiting to get Amp and sub(s) and speakers
I would just make a fork shape out of the copper wire, it would probably give you a better connection than a spade anyway. only negative is it might not look as shinny...
im gonna say fail on that^^^^ u dont want it to slip out and short. forking the wire is never a good way to go. u coud try to shave rings down into forks. pain to do but it will work
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
I would just do what boon said, all you need is a welding cable lug, and some bolt cutters, or even a decent pair of the edged pliers would do it, just to cuts and bam you have a fork.
¿ǝɯɐƃ ǝɥʇ
lol that makes no sense.
cutting rings works but often they are too wide to do the job. splitting the wires into a spade shape is retarded. What size wire are u runinng anyway? if its 2g just strip it down and use a 4g spade. heat shrink the connection and done
J. Jsig_253411.jpgMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS icon_nuts.gif
theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
u can shave them on a grinder. but welding lugs would prolly be the best way to go
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
ya but sometimes it doesn't come out as easy as you'd like. trust me man ive done it before 2g isn't that much bigger then 4g so its probably going to be easier to strip the wire then cut a ring terminal... Most big gauge rings have decent size holes and there's only so much you can grind until your out of metal and running 2g wire to a ring terminal thats ground to the point the "spade" is to thin is sorta stupid
ok man not gonna argue over it im an installer too and i have done it. its just ONE way to do it. everyone has there own idea of whats best
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
  • Who's Online   1 Member, 0 Anonymous, 780 Guests (See full list)
