whats the right way to run 0 gauge wire in a 01 Tahoe under the frame and cut a hole in the floor or take out the carpet and run thru the inside ? ( since it wont go down the side of doors track !!! )
153.3 @ Turkey Drag 2009
Spl Modified 1001-2000 - Derrick Jones my alias... Wudn't accept DEEz NUTz !!!
in my expedition i have 2 runs of 0/1 under my carpet and i have zero problems.
cool i think ill try that this weekend....i did the big 3 now 0guage and batt. are up next....
i worked with my seats in. i just took off the trim panels and lifted the carpet. its a snug fit but it worked. just make sure to keep the wire away from sharp edges/corners where shorts can happen and you should be good to go.
Edited by enemyofsilence
Team Bass-Hz
Mine is under the carpet, but has been there for like 2+ years now... I pulled out the seats/carpet because i used to have multiple runs to the back and it would have been impossible to get them in with everything in place.
But for the most part you can install it will the entire interior in place, only thing is you'll more than likely have to pop off a couple trim panels to hide the wire.
Also can wire under the vehicle, but just need to be sure that you have enough covering to withstand heat and sum abuse from everyday driving.
Pioneer AVIC-N2
cool, preciate the help fellas....imma post my vid. after i get it all in nice and neat....i let the Dallas Tex Flex team check it out this weekend and they said it was loud as hell !!!! ( FOR TWO L7'z ) I just want my power STR8 now.....
hey bro holler at me and im sure some of the guys would definately be down to help you out again w/ running wires and buildin an amp rack and shit
hide the wire
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
  • Who's Online   0 Members, 0 Anonymous, 3033 Guests (See full list)
