98 neon stock altt.
basic battery
i have 2 viair 450;s
and once again i go from 13.75v at idle - to 11.50 while driving and idle, with batter light on
144+ DB'S OUT OF A CONVERTIBLE
12" Funky Pup Subwoofer (The worlds most powerful subwoofer)
6" Aero Ported Box
Hifonics - Bxi2010-D
Pioneer Deck
RD Audio - Front Speaker
Rockford Fosgate - Rear Speakers
KnuKonceptz - 0 Gauge Wire
KnuKonceptz SS Karma - 10 Gauge Sub Wire
KnuKonceptz - Krystal Kable Rca
Big 3 - Upgrade - 0 Gauge
Kinetik - Hc1800 Battery
those two shouldn't pull near enough current to do that. I've got 4 480C's and before I added extra batteries and bigger alternators the lights dimmed a little but that was it.
I would venture to say it is not the compressors causing the problem but they are showing you the problem. I would check the alternator, upgrade to the big 3 and have your battery load tested cause it might be going bad.
Are those comps rated at 200psi, I know that mine draw more amps the closer to 200psi they get cause they work harder.
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
From the site - viair -
12-Volt
Duty Cycle: 200% @ 100 PSI
Max. Working Pressure: 150 PSI
Max. Amp Draw: 40 Amps
whats odd is this is the second time it has happend to me this week any other time im great on voltage,
what i have noticed is that the car starts and drives fine, then when i stop at the local store and go inside for like 10 mins, i come back and it acts up.
6" Aero Ported Box
Pioneer Deck
if i had to guess your alt is going out
definitely sounds like a bad alt....you should think about an upgrade cause your stock alt is rated at 85 amps and those pumps pull 40 to 46 amps...
2000 Suburban 6 runs of 2/0
12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door
475ah of yin long LTOs
Triple 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
compreesion horn amp crossfire 800.4
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
163.5@38hz DBdrag  sealed on the dash… 164.3 outlaw…162.9 Meca headrest
truly the alt...im running viair 480 in my truck with stock alt. and bat. and i havent had a problem yet...in the Prelude all i have are 2 380s and a stinger 1700... never have any problems there... check the alt... then maybe think of doing some upgrade in the future
ima probably buy a new alt, from shity pep boys however i can swap them out all day for free.
then ill get a kinetik battery, i have a hc1800 in my eclipse and it is so nice to have.
this is probley the best route for me cause i just drag the shit out of the car anyways, and all the money goes into the eclipse,... but its kind of hard to rag when your car does not start.
6" Aero Ported Box
Pioneer Deck
When you go and replace the alt, check the wiring harness leading up to the alt. My sister had a 97, and it went through 2 alts in a matter of 2 months. Couldn't figure it out, so my dad took it to a mechanic put it on the lift, peeled back the wire harness outer covering and found a 6" section of wires that melted together and started shorting out the alt. Got it fixed, and drove and was fine for the next couple months she drove it.
But i would suggest that you get a bigger alt, instead of having to replace them all the time. Call up DC power, Irragi, Mechman... and get a price quote for a bigger alt. Might be worth it in the end to do it that way.
formerly known as Blue86f150
this sux camel dicks
like mentioned id get a batt load test done just to see. im running dual viair 380c with a crappy stock batt i had real bad voltage. not thinking it was the batt but switched to a deka inimidator dual post up front no dimming.
  • 2 months later...
I've been having the same problem in my 01 body drop. I got rid of the alternator and upgraded to a 250 amp with a big three upgrade. But I've been through 4 yellowtop optimas and 2 red tops. They get sucked dry. Past the point of recharging. I need to pull the entire electrical for the 2 viar 450s and rewire them. See if that helps.
2004 Mustang
3 18s
6 crossfire bmf 1700s strapped @ .5
161.2 db Daily driver
159.4 @ 45 hz
158.7 @ 35 hz
154.4 @ 25 hz
Team Hz Addiction
http://www.youtube.com/Drek75633
