ok so im running a RE SX 15 off of a hifonics zues at 4 ohm=900rms. but just this morning i heard my sub going bump bump bump nonstop, even when i wasnt playin music. i dont have it hooked up any more cause i know it can be good.... does anyone one what might be causeing this?
RCA connection???
SUCCESS is a decision, NOT a dream. You have to name the price you are willing to pay to get it.
"You didn't have an ice pick on you? Amateur. " -- Wax from Fchat.
Loose RCA? Noise in the system (not likely, but possible)? Broken amp?
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
or a lose ground on amp
2 DC Audio lvl 4 xl 18s D .7s walled off @ 30 hz
19 cubes net 245sq in of port
Sundown 3500 @ .7 Ohm
Sundown 100.4
Rockford Fosgat Power Series
5.25 Dash
6.5 Kicks
8 Coaxils Doors
250 mechicman alt
1 red top under the hood
2 yellow tops in back
big 3 with 1/0 knukonceptz wire
3 runs of +/- 1/0 knukonceptz wire
IT LBS
the amp is not broken cause it def. push the sub when i turn it up, would a loose ground really cause that? cuz mine is screwd down but it just keeps spinning so its not super tight....
figure it out like you would any other electrical problems work your way through the possibilities. Unplug rca's, still does it? check ALL wiring, try with car on/off, i'll bet its one of those three.....or the third option, something is wrong with your amp
Orion 2500D, Jbl Gto 75.4
Team Wolfpack Audio FSQ 15" d2, mb quart xover, tweets peerless 6.5 mids
Alpine cda-105
optima up front Knu klm 1/0
most likely thats the cause of the hissing, does it hiss once you unplug them?
Alpine cda-105
