Go ahead and get the 3000, just keep the gain set super low and you should be fine.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
o gauge 300 watt altenater
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
^ x2 They have great wire and its cheap. for the fuse blocks you could go with knukonceptz or with Darvex you get a discount for being on SMD
1994 Dodge Ram 2500 Cummins Diesel Regular Cab
i would only use the 0 gauge to bring power to the back......then i would step it down from the battery to the amp.... only if it was necessary.
" WELCOME TO AMERICA!!" we speak english here.....
4gauge from the back batt to the amps?
18" DC Level 4
that kit has everything you need, tho i'd probably do another run of negative from the front battery to the back battery. then you should only need small amounts of wire to go from the back battery to the amps
  • Who's Online   0 Members, 0 Anonymous, 3008 Guests (See full list)
