OK, so I need another amp recommendation.
I need either:
An amp that will do 500 watts RMS at 1 ohm
An amp that will do 500 watts RMS at 2 ohm
An amp that will do 500 watts RMS at 4 ohm
An amp that will do about 750-900 watts RMS at 1 ohm
Or
An amp that will do about 750-900 watts RMS at 4 ohm
The one's in bold would be prefered.
Those are my only choices because of my box design. The box will be a Tline and I don't want to risk damaging the sub by putting more then it's RMS on it (which Forevrbumpn said in his tutorial might happen).
I'd prefer to keep it as cheap as possible because I haven't worked lately due to a foot injury, so I don't have much money and probably won't for a while.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
what sub will you be using?
500rms@4 is a lot of fcking amp for a tline, unless youre going BIG.
Edited by BanginOnABudget
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
I was thinking a LVL3 12", which I know I can fit. 1, 2, or 4 ohm will do, as long as it does 500 watts RMS cleanly.
I'd be willing to do a LVL4 12", but it'd be a while before I could.
15.4" widescreen
What it does:
Would this be a good amp?
http://www.sonicelectronix.com/item_19812_...am+Di475.1.html
Specs:
475x1@2-ohms
PWM MOSFETpower supply
Bass knob included
LED power indicator
SMD technology :)
blah-blah-blah
15.4" widescreen
What it does:
Anyone? Oh well. If no one has anything bad to say, that's the amp I'm getting as soon as my paycheck starts coming in again. :) I hate not having a paycheck.
15.4" widescreen
What it does:
Hifonics bx600, don't know if they still make it anymore but it used to do like 500-550 @ 1ohm.
Pioneer AVIC-N2
Can't find it. Oh well. What do you think of the Soundstream amp I posted?
15.4" widescreen
What it does:
OK. So I have 3 different choices to think about. Hmmm...
Anyone ever use one of these three amps?
http://www.sonicelectronix.com/item_19812_...am+Di475.1.html I know it's cheap, but I've been unable to work because of a severe injury. I'd be able to buy this one after 1, possibly 2, weeks once I get back to work.
http://onlinecarstereo.com/CarAudio/p_2139...ate_R500-1.aspx A bit more expensive and definitely out of my price range for now. But it's an RF, sooooo.....
http://www.onlinecarstereo.com/CarAudio/p_...cs_BXI_610.aspx Dam near perfect for my needs. About the same price as the RF, so It'd be outta the question for at least 3 more weeks while I get back on my feet. But not impossible.
15.4" widescreen
What it does:
Specs:
475x1@2-ohms
Bass knob included
LED power indicator
SMD technology :)
blah-blah-blah
hahahahahaha that had me rolling.
