how do i seal my trunk?
I want to make the subs be where my seat is and i was wondering how to seal a trunk? and make basically a ported box
gonna run 1 or 2 audio que 15's sdc in a 2002 ford focus se
hopeful noob
It's easier to build the box firing into the cabin of the car and seal it off from the trunk, or is that what your asking?
expanding foam is your friend ha check my build if needing any ideas. i have a single DC 15 sealed off but removable too to get at my spare tire if needed
well i was thinking that using a flat piece of mdf where my seats fold down to mount my subs using the whole trunk space as my box sorry for my noob ideas
hopeful noob
could i make a box then a "face plate to blend it into my trunk opening from the back seat? would that afffect performance?
i would like a smooth flush look
hopeful noob
Your two main concern's for any type of enclosure is first tuning (Size of the enclosure, port area) second the rigidness and ability to hold high pressure soundwaves. Becuase your trunk is made of sheet metal it's generally a bad idea to use it as the backend of your enclosure. Here's two threads that might be of interest to you:
1. http://audioforum.termpro.com/topic/40/24075.html
2. http://audioforum.termpro.com/topic/40/23754.html
Goodluck eitherway friend!
If I understand you right you want to just use your whole trunk as the inside of the box? Like the steel is the mdf? If so I think you should just build a box instead because it will be much stronger and louder. Sorry if I misunderstood though >_>
  • Who's Online   0 Members, 0 Anonymous, 1800 Guests (See full list)
