Hi,
Sorry my english is a bit bad.
I have 2x12" Dynabel DY9412 in my car. They are in a closed enclosure. They kick really well but i think it much more to get out off them.
I want to try out a portet box but i cant calculate what size the port and box must be. And to what tune to build it to. is 38hz god or shall i go lower. The reason i ask on this forum is because you guys have some sick stereos and it looks like you know what you are doing!
Can someone help med calculate the box and give med the dim on the box?
The box i have now is 30liters per sub minus the magnet
I want to have a box like this or with port on each side.
THIS IS JUST A EXAMPLE, NOT MY PIC:
Sensetivity (2,83v 1/m): 91,0 dB
Fs Hz: 39
Qts: 0,30
Vas, liter: 22,0
XMAX: 22mm
Closed box: 30 liter
Ported box: 30 liter
Port: 2 Stk 70*380
Chassi: 322mm
Mount diameter: 285mm
Mount depth: 165mm
RMS: 800watt
Peak: 1600watt
Edited by noXelon
where did you find those subs? i have some 11"s that have a 6 mag not an 8 mag setup. that fucker could GET IT!
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
norwegian brand :good: berniebp87 got 2 of their amps in his car :)
plays very well when the box is rigth ^_^
my english isnt that good, so if i misstype a word, or dont bend it rigth, dont scream, just notify me ;) then i learn :)
Do you know what kind of box hi is using, maby give me the the drawings? (A)
Norwegian brand subs, plays really well, for the price about 230 dollars a piec. I am feeding the woofers with 450watt RMS each, really want to buy a bigger amp, but money is short right now. Next amp will be Dynabel altso, but only this time 750watt RMS each!
They have a loong xmax, so there is a gooood punch! I can make a video later and post it on this forum! ^^,
"I would man but i cant do liters. just give it some time im sure someone will be able to help."
What do you prefer?
Edited by noXelon
