d18 Posted October 22, 2009 Report Posted October 22, 2009 I'm planning on upgrading my dell dimension 5150's processor. The 3.2ghz stock single core isn't cutting it anymore. I've upgraded everything else on this computer, if I hadn't I would definitely build a brand new one. Anyway the specs im currently running are : 550w psu nvidia 8800gt intel 3.2ghz single core 4gb ram Now onto my question. Will an intel e5300 ( http://www.newegg.com/Product/Product.aspx...N82E16819116074 ) or an intel e6300 ( http://www.newegg.com/Product/Product.aspx...N82E16819116091 ) be compatible with the stock mobo? It's an LGA 775, but I don't know the exact specs. I contacted dell and they were no help... All they could tell me was that it wouldnt support a quad core. Quote
Boon Posted October 23, 2009 Report Posted October 23, 2009 (edited) I HIGHLY HIGHLY doubt any Core2 CPU will work with your board if it originally had a single core CPU in it. Your best bet is probably to get the fastest P4D you can but that will end up costing you so much that you may as well throw the CPU and motherboard in the bin and get a new mobo with a middle of the road quad core CPU. EDIT: BTX chassis. So you throw the case in the bin as well, and probably the PSU. EDIT EDIT EDIT: You're pushing wet sloppy shit up an icey ramp with a rake wearing rollerskates man. Sell the lot. Edited October 23, 2009 by Boon Quote 10.x volts fo' life!
d18 Posted October 23, 2009 Author Report Posted October 23, 2009 I HIGHLY HIGHLY doubt any Core2 CPU will work with your board if it originally had a single core CPU in it. Your best bet is probably to get the fastest P4D you can but that will end up costing you so much that you may as well throw the CPU and motherboard in the bin and get a new mobo with a middle of the road quad core CPU.EDIT: BTX chassis. So you throw the case in the bin as well, and probably the PSU. EDIT EDIT EDIT: You're pushing wet sloppy shit up an icey ramp with a rake wearing rollerskates man. Sell the lot. So that's a "more than likely no" ? Quote
Boon Posted October 23, 2009 Report Posted October 23, 2009 It's a definite no Quote 10.x volts fo' life!
BJD3 Posted October 23, 2009 Report Posted October 23, 2009 I HIGHLY HIGHLY doubt any Core2 CPU will work with your board if it originally had a single core CPU in it. Your best bet is probably to get the fastest P4D you can but that will end up costing you so much that you may as well throw the CPU and motherboard in the bin and get a new mobo with a middle of the road quad core CPU.EDIT: BTX chassis. So you throw the case in the bin as well, and probably the PSU. EDIT EDIT EDIT: You're pushing wet sloppy shit up an icey ramp with a rake wearing rollerskates man. Sell the lot. I am so sigging that. Quote Anti Peel and Seal...lol You may be offended by the above. Don't take it personally, I'm just abrasive. 2002 Buick Park Avenue DC Level 4 M2 12 D2 Car Audio Bargain 1600.1 Eclipse CD3200 ~2 cubes @ 34 hz. Stinger Roadkill Expert
newls1 Posted November 3, 2009 Report Posted November 3, 2009 I HIGHLY HIGHLY doubt any Core2 CPU will work with your board if it originally had a single core CPU in it. Your best bet is probably to get the fastest P4D you can but that will end up costing you so much that you may as well throw the CPU and motherboard in the bin and get a new mobo with a middle of the road quad core CPU.EDIT: BTX chassis. So you throw the case in the bin as well, and probably the PSU. EDIT EDIT EDIT: You're pushing wet sloppy shit up an icey ramp with a rake wearing rollerskates man. Sell the lot. extremely well said! Stupid dell and there (then) proprietary designs and PSUs. Now there finally building them the "ATX" way, but back when the OP bought his computer, dell was.......well, DELL! Quote I love my staffie So anti FACEBOOK it isn't even funny
