No it is not ok to run 2 different subs in the same enclosere. I wouldnt even run 2 different subs in seperate enclosures.
And here it shows they are not 3000 watts RMS.
12" Pioneer Premier 3004SPL Subwoofers
3000 Watts/1000 rms
System Specs:
Alpine SWR-1542D 15" sub
Sealed Subwoofer Box
MTX mxa 6001 Class D 774watts RMS @ 2ohms
MTX Bass Knob
Pioneer 6.5's in doors
MTX Thunderdome 6x9 in rear
Stinger 1 Farad capacitor
80 amp stinger fuse
BIG 3 in 4 gauge wire
4 gauge power/ground wire
JVC MP3 CD Car Deck (KD-G320)
12 gauge Monster speaker wire to Sub
16 gauge Stinger speaker wire to doors
Stinger Gold Plated Battery Terminals
alrite .. i guess its time to change the sub!! thanx for the advice bro..
is there anything else i should do like loading capacitors , alternators or wires?!
one thing you could do is the Big 3. Change your engine grounds, battery ground, and alternator ground. This will help with the flow of electricity within your car.
System Specs:
MTX Bass Knob
80 amp stinger fuse
hmm.. what is this Big 3?! i dont think these things would be available here but still i'll ask my mechanic about it.. he'll surely can tell me where can i find these stuff... n what should i change these grounds with?? some bigger grounds ?!
change them with the same power wire used for your amps. Preferably 0 gauge. But 4 gauge will work fine. It only takes about 30-45 mins.
System Specs:
MTX Bass Knob
80 amp stinger fuse
Posted (edited)
thanks man i'll surely do that and do i also have to change my factory fitted head unit cause my
retailer told me that it doenst have an equilizer or subwoofer option...? will it make ne difference and if yes then which HU would be better?! pioneer 7950mp or 880prs??
Edited by durty_riz
GET THE 880 PRS!!! i have it and its the best head unit iver ever used. and yes it will make a huuuuuuuge diff.
DD M4
Rockford Fosgate P500-4
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Guest Nismofreak
I'm sorry but.... is this alpine with an ip-changer like HideIP or something? :unsure:
If not, sorry again :rolleyes:
Well alpine is to stupid to even do it. HAHA.
