Problems with my Big # in the Focus!! HELP!!!!
Hi all I was atempting to do the big three today on my 03 Focus ZX4 Got the ground to body. and ground to engine with no problems. I got lazy by this time and tried to do the Alt. to battery while it was still hooked up to power. Needless to say It grounded out. I heard a POP down in the starter/ALtenator area. It stated back up fine ater that but wasn't charging If I moved the wires On the alt it would start charging then Stop. I shut it off and reattached the factory wire from the alt and now nothing. Ive got full power to everything but It just Clicks. Could it be the Starter died from this. Never had this problem before. Please help!!
Edited by CFAIST
C.A.R. AUDIO
Faist Audio Concepts F.A.C.
96 Escort wagon Murdered out (redneck style)
Eclipse HU, CDT classic Components
ED Nine.2, Hifonics 1608d (borrowed)
2 Powerbass M 15"s 6 cubes tuned to 30 hz
2005 State record holder 0-600 Consumer 143.7 USACi Kick (1 Soundstream SPL15, JL e1200)
2009 3rd Loudest 0-1000 Trunk In Iowa USACi 145.00 kick. (4 Powerbass PS-10's US AMPS MD3D)
146.2db Unofficial. 6-ps-10's MD3D. Personal best 150.9DB 4 Powerbass M-15Ds. American Bass VFL150.1 at .5 ohm
2010 Usaci 0-1000 mod Iowa state record holder 149.4DB
Check out my youtube channel CFAIST1
I have an 01 ZX3 and I'm not sure how similar these two are but I was messing around with the alt and didn't tighten the nut up enough and the alt wasn't charging. I got back under the hood and tightened the shit out of it and it started to charge again. It wasn't making a good contact so it wasn't charging. Maybe you need to check it again to make sure you put the wire back on tight enough.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
146.4 sealed on the dash at 37hz
2001 Focus ZX3: RETIRED
Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore Champion
Highest NSPL Scores to date:
154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz
155.2db unofficial on dash at 43hz
well if it gounds out through something it could have fried it. the socket wrench hit my wiper arms when i was taking off my alt + and it fried my wiper motor. so look whats attached to the spot that the wire touched and see if you can trace what might have fried.
I've got it on the charger right now, to see if the batt. just got that drained, It reads 12.49v without a load on it but when I try to start it it drops down to 6.8-9volts. Hopefulley that is all my starting problem is. if it starts in a while I'm gonna try an tighten the alt connection up to make it charge. thanks for the input guys.
C.A.R. AUDIO
could be that your started is messed up and is drawing way too much current... but i dont know much about cars.
had the same problem on my 02. the factory wire coming off the battery that is 2 runs of 8 ine supplys the starter with power. so run your 1/0 from your alt to your batt. then cap off the factory wire on the alt side. then reattach the factory ring that has the 2 runs of 8 ant it will charge and start fine
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
Well, I went back out this morning and my Charger was off, and the car was DEAD! So I checked the batt. with my DMM and it read 13.56 Volts. So I dug out my ariginal Battery which is tiny and tested it it read 11.49 Volts I figured what the hell maybe It smoked a cell in my Big battery. I installed my original and the car fires right up. Still has the battery light on like it's not charging. :aggressive: Don'tknow WTF? did I smoke the voltage regulator in my Alt? or just dont have a good enough connection. While it's running it doesn't drop voltage like it was but it doesn't read like it's charging.
C.A.R. AUDIO
Well I've got everything back up and runing now. Charging at 14.6Volts whe the system is at full tilt. Only prob now is my Spedo is stuck on 140 mph. Hopefully I didn't kill that. Anyways Thanks for all the help guys I really appreciate it.
C.A.R. AUDIO
  • Who's Online   2 Members, 0 Anonymous, 1620 Guests (See full list)
