This is a Reducuer
http://www.darvex.com/SPT821/Stinger+0+-+4...ge+Reducer.html
And the zip tie trick is you take a zip tie, and put it near the end of the cable that is stripped back, and you pull the zip tie tight therefor sqeezing the strands together, so it is easier to fit the wire in a smaller hole.
GYA!!!! that's the one. But what about for speaker terminals? Even on my Zapco 9.0 I can't fit 8 in it and 10 with a terminal has to be trimmed to fit WTF!!!!
Starting From Scratch!!
solder the end and grind it down to desired size. does the same thing as the reducers but costs less assuming you have solder on hand
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
one side u stick the 1/0 in...the other side is straight aluminum (or whatever metal they use) that fits into the amp...
like in the above link...the point on the right side goes directly into the amp
Edited by andym85
i likes me some audio stuff...
