you will be much happier with birch ply if you are comfortable your enclosure design is proper. Birch ply is stronger and WAYYYY lighter than MDF of the same thickness, and its most likely only a few dollars more in your area. the weight savings alone is worth the switch.
and if you have any problems with bracing use some threaded rod :)
x2 i love birch. birch>mdf anyday IMO
Team Bass-Hz
Now I work at Lowes and I can tell you Birch isnt twice as much.. is $5 more dollars per sheet here.. Is the Birch sheet your looking at Birch/Maple.. now thats about twice as much as MDF..
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
For a 60lb woofer and 2kw I'd suggest a double baffle plus sum bracing. I've done flush mounts in the past also and it is somewhat difficult to get a heavy sub out(when its subs are facing upwards).
Pioneer AVIC-N2
maybe thats what it was, ill stop by today and check it out
02 Chevy Trailblazer
18" DC XL
build in progress...
refs: ak1167 (bought tweeters from)
so go birch 3/4 all the way around and double it for the baffle? if i use fiberglass inside will i still need bracing?
18" DC XL
forget the fiberglass and use bracing. much faster and cheaper.
  • Who's Online   0 Members, 0 Anonymous, 3135 Guests (See full list)
