I'm kinda in a hurry so:
My copy of windows arrived with both the 32 and 64 bit versions. I have a Compaq Presario V6120US with upgraded 2 GB memory and 500 GB HDD. Which should I use? 32 or 64 bit?
Thanks in advance!
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
I would do 32 just because I've had a few software compatibility issues with 64. Other than that 64 is supposed to be better if your system can take advantage of it.
I don't use much software. Firefox, some video editor (forget the name), audio editor (Roxio Music lab 9 for now), Itunes, and plan on trying my hand at Photoshop if I get the money.
I don't know whether my comp came with 64 bit or 32. I got a free upgrade to Vista when it came out (HP just sent me one, dunno why; my comp was designated Vista compatible).
Does anyone know?
Edited by 1992Chevy K1500
15.4" widescreen
What it does:
Anyone?
15.4" widescreen
What it does:
The main differences between the 32-bit versions of Windows Vista and the 64-bit versions of Windows Vista relate to memory accessibility, memory management, and enhanced security features. The security features that are available in the 64-bit versions of Windows Vista include the following:
* Kernel Patch Protection
* Support for hardware-backed Data Execution Protection (DEP)
* Mandatory driver signing
* Removal of support for 32-bit drivers
* Removal of the 16-bit subsystem
One of the greatest advantages of using a 64-bit version of Windows Vista is the ability to access physical memory (RAM) that is above the 4-gigabyte (GB) range. This physical memory is not addressable by 32-bit versions of Windows Vista.
Depending on the version of Windows Vista that is installed, a 64-bit version of Windows Vista supports from 1 GB of RAM to more than 128 GB of RAM. The ability to address more physical memory lets Windows Vista minimize the time that is required to swap processes in and out of physical memory. Therefore, Windows Vista can manage processes more efficiently. This memory management feature helps improve the overall performance of Windows Vista.
Advantages when you install a 64-bit version of Windows Vista
* Increased memory support beyond that of the 4-GB addressable memory space that is available in a 32-bit operating system
* Increased program performance for programs that are written to take advantage of a 64-bit operating system
* Enhanced security features
Thanks for the info Herrie. According to wht I've found, my processor (AMD Turion 64 X2 Dual-Core TL-50) is a 64 bit. Do you think I'll be alright with only 2 gigs of memory? Also, according to wht I found, my MOBO only supports 2 GB's of RAM. But could it support more for a future upgrade? (Like way later in the future).
15.4" widescreen
What it does:
my guess is its windows 7? I'd go 64 bit personally. Most everything out there will run 64 bit now. (most)
No to your MOBO..it will only support what it says. Also keep in mind that if you switch out mobo in the future you won't be able to use your OS key again.
Edited by sayhuh?
10501650_10203332501847103_1859383749711
Blown
Ok. I'll put in 64 bit. But HP said my MOBO would only support 2 GB's, I never found info on the MOBO itself other than that.
OHHH, and yeah, it's Windows 7. Sorry I forgot to mention that.
15.4" widescreen
What it does:
Yea I found out the hard way about changing MBs and OS systems...at least this is what MS told me when I couldn't install it on to my new computer. I thought you would just have to do a fresh install but it wouldn't let me activate.. I told them the other mb was fried and needed a new one. LoL fuckers.
Edited by sayhuh?
Blown
Yea I found out the hard way about changing MBs and OS systems...at least this is what MS told me when I couldn't install it on to my new computer. I told them the other mb was fried and needed a new one. LoL fuckers. Now i just get OEM any time I change OS or redo my comp. =)
OK then. I don't plan on just changing anything else. Maybe I'll get lucky and it'll give out just as Microsoft releases it's next OS. Then I can just upgrade again. I plan on having this comp till after my freshman year of college (or whenever I have money to build my own).
Anyway, I'm installing now (I'm at 1% :):(:D) and can't wait. I'm excited to finally have my comp again.
And thanks to all those who helped me!
15.4" widescreen
What it does:
  • Who's Online   0 Members, 0 Anonymous, 3517 Guests (See full list)
