is kicker amps like the zx1000.1 any good? as in do they overrate it? and will it run 1000 rms on 2 subs at 2ohm or just break it down into 500 rms per sub?
thanks ahead of time
How would it be able to run 1,000 RMS to 2 subs if it's only a 1,000 RMS amp? Yeah it'll break it down to 500 RMS per sub, and kicker amps usually do rated from my experience
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
the zx series are not over rated... they do right at or just a lil over... i believe sablenaves birthsheet on his says a little over 100watts more...
if you run 2 subs each woofer will see 500rms... if you run 1 sub it will see the full 1000 assuming in both cases it is a 2ohm final load...
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
Mine Birthsheet says 1161 watts, and they are very good amps. What is your electrical system like on your car? You are going to need a high output alternator as well as a secondary battery
Car
1996 Sable LS
8,000K Bi-Xenon HID's
Pioneer Premier DEX-P1R
Diamond Audio D351, Diamond Audio D362i, Diamond D3TAK off Kicker ZX200.4
Custom 15" 13w7 motor, 3.5" aluminum coils dual 1 ohm off NV-AM25001
Dynamat Dynaliner Second Skin Damplifier Pro
Stock 130A Alternator
My Build
Truck
1995 Ford F-150 Flareside XLT
10,000K Bi-Xenon HID's, 15,000K Bi-Xenon HID's
Kicker KS6502, KS400 off Pioneer Premier PRS-D4100F
Truck Build
Ref(s) Rogers, Jared, Mikesmith0890, Twigz, DHFHades, BASS14, Solo_X18, mrafrica, camino_1to3, kickerassman
[speakerman9000] 5:43 pm: if sony sucks so bad how come my amps still work when i had 3 12s on it
[capalass23] 11:27 pm: wow u grand man poopin out babys like hto cakes
[KevinniveK] can u have sex later please hes helping me
The ZX amps are very high quality and for the most part are a little underrated. To wire 2 woofers to a final load of 2ohms you will need - 2 D2s or 2 S4s. I was guessing that the OP might have needed help with that also.
To the OP - if u need sum help just toss me a PM.
Pioneer AVIC-N2
  • Who's Online   0 Members, 0 Anonymous, 1041 Guests (See full list)
