Mechman Alternators
Question about the Mechman 250
I had the alternator installed a little under a month ago. The first time I drove my blazer with the alternator on it made a noise when I went above 2500 rpm's and it still does it now. If it is not above the 2500 rpms then it doesn't The noise sounds something like a supercharger and a high powered fan running at high speeds. It will only happen when I accelerate over 2500 rpm's or when i'm trying to pass someone up and push on the gas. Is this a problem or does this alternator has a fan built it to keep it cool cause it is pushing out alot of amps. I just want to make sure it is not hurting my vehicle.
Thanks,
Dennis
YEAAAAA!!!!!!!!! Let's get em
4 JL Audio 12w6's (wall)
4 Pioneer 6x9's (built into the wall)
4 Memphis 6.5's components (one set in kick panel and one set in the door)
Orion 2400 amp (old long black amp)
Orion 800.4 amp
Mechman 250 amp rhino series alternator
0 guage everywhere
Kinetik 2000 for bass
Kinetik 800 for highs
Memphis Digital Processor
147.1 db @60 hertz
it should be normal. most high output alternators make a supercharger noise. the noise will be significantly louder IF it does have a strong fan attached.
8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee :DClick to see J00bles' Youtube Channel
i have that noise too works fine, just the sound its producing current
Correct. We also use high-efficientcy fans for better cooling. They move more air, and are subsequently louder.
  • Who's Online   2 Members, 0 Anonymous, 530 Guests (See full list)
