3 Sundown 1500's...need maxxlink?
tristan560
If you have a good dmm you can gain match them,
but the saz amp dont have daisy chain abilities. so splittin the signal from 1 to 3 might cause a problem. like splittin the rcas in to 2 then splitting one of those 2 in to another 2. you might have one rca set with half the original voltage, and the too others with a quarter of the original voltage.
so a four volt deck is now down to 2 volts, 1 volt and 1 volt.
seems like a maxx link is easiest.
That setup will work fine without a Maxx-Link. I ran that same exact sub/amp combo for a bit a few years back. Worked great.
Rca voltage doesn't split like that. Even if someone uses a Maxx-Link you still have to match all the amps. Since the Maxx-Link uses single channel sub outputs y-splitters will still be needed to use three amps.
  • Who's Online   1 Member, 0 Anonymous, 1820 Guests (See full list)
