how much rms can i put on a 300 amp alt and 2 d3100's? would 2 saz2000's be fine without any voltage drop?
Chrysler 300 on 24's
(2) audioque 2200d's [subs]
(1) audioque 4x90 [highs/mids]
(2) 12" DC audio level 4xl's
(2) xspower D3100's
Iraggi 320 amp alt
Big 3, 2 runs of 1/0 guage
Box 4 cft tuned to 30hz
id prolly put at least one big battery per amp as well
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
damn, if that all the power i have now would you go with a saz3000, or a 3500?
(2) xspower D3100's
Iraggi 320 amp alt
Not at full tilt.
You should be fine tho.
You already got an alt?
no my batteries just got here yesterday, my alt's next on my list
(2) xspower D3100's
Iraggi 320 amp alt
id buy one more battery if you can fit it....
Full eclipse system is next on list.. soon to gut and redo the honda as new project/rolling buissness card :)
i miss the sound of those old school strokers on beast amps :(
I run a little case 170amp alt (Acura Integra ls) , 2 XS D3100's relocated in the rear with Knu 1/0 wire. They are also my main starting batterys as I ditched the little 51R group size one under the hood.
Running a single Sundown saz-3500d @ 1ohm , the voltage never drops below battery rest 12.9v-13.2v and usually is around 13.6v running full tilt. I keep them charged though but if I roll around with the amp off the batterys will stay pretty full , just charge to keep them topped off.
I set the idle on the engine to 2,000rpms so the alt is putting out as much as possible at idle. Factory warm idle was 600rpm.
2000 Trans Am ws6 - 6spd / M9 / cam / full bolt-ons / semi full suspension / tune
1998 Integra - daily beater, [2] AB XFL-1244's / 4ft³@35Hz, 61in² / Saz-3500dv1 @.85Ω
You set your idle to 2k? Your joking right?
Dodge Magnum with custom 300c front end, laid out on air bags
*4) 12" Cadence Daytona walled
*1) AudioQue 20k
*270a DC Power Alt (Dual coming soon)
i have a dc 270xp alt and a yellow top under the hood... 5 runs of zero gauge to the rear with a batcap 4000 in the trunk
saz 2000d amp... and im always at 15.x volts... never any drop... i'd say you'd be fine
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
  • Who's Online   0 Members, 1 Anonymous (See full list)
