here are my box specs
H: 15"
W: 33"
D: 28"
here are the pics of my design i dont know if i can do my port like this but i believe its tuned around 32-33hz i used bass box pro but added my own lil twist to it
it will be for 2 pioneer premier champion series 12 TS-W3002d4(http://www.sonicelectronix.com/item_16665_Pioneer+Premier+TS-W3002D4.html) and the amp pushing them will be a MB Quart DSC2000.1D(http://www.sonicelectronix.com/item_17762_MB+Quart+DSC+2000.1D+-DSC2000.1D-.html)
CB7 wit bang
looks nice... when will you start building it? what amp are you going to be running ?
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
That port is quite close to the back wall, I can see sum port noise in your future.
Pioneer AVIC-N2
i think it's a good amount of airspace... but looking at the rendering and seeing what marlo said above... you might end up getting some port noise
how far should it be from the back wall?
if you have any ideas or suggestions to make my enclosure design better for me be my guest always up for any changes to better my design
Edited by skinneyfinney17
CB7 wit bang
Rule of thumb generally is port should be 4" or more from the back wall to prevent port noise/allow easier air flow.
Pioneer AVIC-N2
the distance is fine, technically it should be half of the port opening since both ports are sharing that space. but the port ratio is what may cause noise. i believe it needs to be around... 1:7?
ok so i should be alright
do u guys think i should put some bracing(dowels) in my box and if so where should i place them and i plan on putting 45's in every corner and fiber glassing the inside with some woven roving cloth( i kno overkill)
CB7 wit bang
  • Who's Online   0 Members, 0 Anonymous, 928 Guests (See full list)
