BNIB RE SEX 15 ***SOLD TO TUDSKI***
For Sale:
(1) Resonant Engineering SE-X 15 D4 15 Inch Subwoofer. Price dropped to $150 shipped for a BRAND NEW RE SUB!
This is the new version of the RE Audio SE subwoofer. The cone is similar to the old SE, but the basket, motor, and spider are all different.
This is a new subwoofer that has never seen power. It is 10/10 Cosmetics and 10/10 Function. The SE-X is a very nice sub that would be perfect in a cost-effective daily system where an alt and extra batteries are not in the cards. This thing has 18mm of linear Xmax, so its output and low-bass potential is very substantial.
Specs:
Mounting Depth - 6.75"
Mounting Hole Diameter - 13.75"
Overall Diameter - 15.5"
Bolt Hole Circle - 14.75"
Motor Width - 6.25"
Motor Depth - 2.5"
Basket Depth - 4.25"
Displacement - 0.16 cu. ft.
Weight - 16.5 lbs.SE SERIES
T/S Parameters:
Electrical Q Value -Qes: 0.45
Mechanical Q Value -Qms: 4.87
Total Speaker Q Value -Qts: 0.41
Free Air Resonance -Fs: 23 Hz
Equivalent Compliance -Vas: 203 liters
One-Way, Linear Excursion -Xmax: 18 mm
Efficiency -SPL 1W/1m: 87.6 dB SPL
Effective Piston Area -Sd: 810 cm^2
SOLD to Tudski. Sorry, guys.
PICS:
Sub comes with the Original RE box, manual and RE window sticker. :hairtrick:
SOLD
I have never seen this sub? Is the the newer Re sx sub? I don't know i could be wrong..
It is the new, improved version of the "SE" subwoofer. Now, instead of having the generic basket the old SE's had, the SEX has RE's own proprietary basket adopted from the XXX and the MX subs.
This new SEX sub is an extremely nice woofer. It has a heavy gauge aluminum basket, a looong 3 inch coil, and a huge soft surround on the front. The pics don't do it justice at all, but here are a couple others:
Here is a link to RE's own info on the sub:
http://reaudio.com/specs.html#sp_sex
The Old SE's looked like these:
RE recommends 3-4 c.f. ported for this subwoofer and 2-3 c.f. sealed, so it will fit pretty much any vehicle.
POSTED 11/5/2009: I will throw in a FREE PORTED BOX DESIGN for the purchaser of this subwoofer.
Man i like those subs some peeps is telling me on here that im old on news i need to be updated can some peepshelp me out
If you want to update your system, then subs are probably on the top of the list (that's why you're on SMD, right?). The new RE SEXs are a very good start. The only possible issue you might encounter with this sub is that is has dual 4 ohm voice coils (as apposed to dual 2 ohm). What this means is that you won't be able to use just one of these to get the max power out of a typical class-d amplifier.
The good news is that this sub will play great on a 1200-1500 watt RMS amp at 2 ohms. Later, if you want even more bass, you can get another SEX for a great daily listening setup.
Be forewarned though, your next SEX 15 will likely cost more than $190.
Thanks.
Sorry but how do these sub compare to L7 15.?????????????
Alpine D900 head unit 7" flip out t.v
Kicker 6 1/2 components (front,rear)KS 6502
MB quart 3 1/2" in front A/C vent's (center channel)
DC Audio LVL 5 18" (pair) Custom ported box
Sundown 4500 at .5
Sundown 100.4
XS 3100 up front and a pair of XS 6500 in the rear.
1 17" Eiger Vision T.V
2 7" Eiger Vision T.V in Second row.
Dynomat Top to Bottom (foam in all halo beam's)
DC Eng Alt 260SP and a 400SP dual set up.
big 3
Sitting on 24"
If your neighbor don't complain it's not Loud!
So you best go fix your shit !!!!!!!!!!!!!!
