milesmiles Posted November 2, 2009 Report Posted November 2, 2009 So last night I offered to bring my trusty 10" to a dance party just do add some extra kick to the music. The setup was to be as follows: Ipod going into the RCA inputs of my amplifier, RCA's going from the outputs of the amplifier to the line inputs of a self powered PA speaker. The Ipod hooked into the subwoofer amp worked just fine. But whenever I plugged the output RCA's into the PA speaker, the sub got pushed at a constant frequency (like 50 hz or so); even when I turned the gain all the way down on the sub amp, the sub was still moving! Crazy... Additionally, no sound came out of the PA speaker. WTF do you think happened? I was thinking that the problem was somehow electrically related...
Guest Posted November 2, 2009 Report Posted November 2, 2009 did you try different RCA's? sounds like a bad ground to me. but what do i know.
HHR Ed Posted November 2, 2009 Report Posted November 2, 2009 PA speakers have an input sensitivity at a much higher level than a pre-out RCA. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
milesmiles Posted November 2, 2009 Author Report Posted November 2, 2009 PA speakers have an input sensitivity at a much higher level than a pre-out RCA. Yeah but when we plugged the ipod straight into the the PA speaker (using RCA's) it worked fine.
tacomabanga1986 Posted November 2, 2009 Report Posted November 2, 2009 can u give a name of wut kinda stuff u was useing so we get an idea on how to hook it up? ive hooked up some wierd shit in some cases n it work n jam like all hell so i might can help here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp here's a link to my other system my 90 geo prizm test car heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
milesmiles Posted November 2, 2009 Author Report Posted November 2, 2009 Alright, one more detail: The RCA's we tried to use were actually the RCA section of the red-white-yellow TV cables we all know. Could that have caused the problem? Thanks.
tacomabanga1986 Posted November 2, 2009 Report Posted November 2, 2009 just try splitting off the rcas comeing off the ipod from the input of the stereo n then into the pa amp n should be fine, whats wut i always do the output might be bad on the recever not sendin a good output signal and ya pa stuff is regulated alot diff than normal home stuff is, takes alot higher preamp voltage than most other recevers to here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp here's a link to my other system my 90 geo prizm test car heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
Boon Posted November 2, 2009 Report Posted November 2, 2009 Earth loop is causing the hum. 10.x volts fo' life!
Dustin Posted November 3, 2009 Report Posted November 3, 2009 So last night I offered to bring my trusty 10" to a dance party just do add some extra kick to the music. The setup was to be as follows: Ipod going into the RCA inputs of my amplifier, RCA's going from the outputs of the amplifier to the line inputs of a self powered PA speaker. The Ipod hooked into the subwoofer amp worked just fine. But whenever I plugged the output RCA's into the PA speaker, the sub got pushed at a constant frequency (like 50 hz or so); even when I turned the gain all the way down on the sub amp, the sub was still moving! Crazy... Additionally, no sound came out of the PA speaker. WTF do you think happened? I was thinking that the problem was somehow electrically related... The problem that you experianced was that you did not have a mixer to runn it to so onces you purchase a PA mixer you should not experiance that problem i work around with pA,s at the time because my grandpa runs a gospel group but if you do buy a mixer for that PA speaker and its still doing the same thang it might be a shortage inside the PA box if it is old or if it is new it might be a factory malfunction in the product its self.....I will not be responsible for any of this if you listentro me i am just telkling you what i would do if i was you. Car Owned:2000 Malibu Stereo:Ken-wood kdc 2022 # Of woofers 4 Amp:Ken-wood No capaciters all woofers are 12" Amp wattage 600 watts (SMD) MALIBU CUSTOM AZUL TYPHOON ADDITION OR A.K.A___M.C.A.T.A
