how much power can a dd9518 take ? im going to put a saz-3000d to a dd9518 d2 paper cone.
Edited by 91explorer
Head unit Pioneer deh-80prs
Sub Amp
Highs Amp Skar audio Lp 60.4
Tweeters and Highs 2 Skar audio fsx 6.5 and 2 spx-t
Subs
Batteries?
alt?
That should be fine ...just watch your gains...i've seen close to 3K put to them daily!
My POS Bass machine-
2003 Hyundai Santa Fe on some shitty 22's
Bed Liner Paint Job-Pioneer AVH 3200DVD
4 DAD BD series 15's in a 4th Order (Bassheads ENT Design)
4 Arc Audio XDI2000.1 for the woofers
6 Cadence CVL68MBX 6.5's-Cadence CVL88MBX 8's-6 Cadence XT20 Supertweeters
2 Arc Audio KS300.4's for mids and tweets
1 Arc Audio ALD 10v Line Driver
All Audiotechnix Power wire
1 DC Power 270XP High Output Alternator
1 XS Power D3400 up front....6 XS Power D3100's in the rear
Air Lift 1000 Bags in rear to help with suspension
If your still reading this GFY.......
my buddys a dd dealer and all the dd 9518 he uses have around 5k on daily
edit:but you have to have some volume control
Edited by fischy fisch
lol. but i haven't and i don't plan on it. plus i'd probably miss and hit her belly button or her ear or something. lol.
I hate to do this but i call bullshit on a true 5,000 watts daily on a 9518....
belive what you want man ive seen it he has runs 2 candence ia 9's on his 18's if you turn the gains down a lil you can do it
edit:plus you can get a stiffer spider
I ran two 9515 on 4 Earthquake phd5000's and 2 stetsom 7kd's daily. For burp I ran 4-Stetsom 7kd's and 2 14k2d's, Only burned coils once and the first subs lasted almost two years on the d5's, reconed for lower impedience and ran the 7kd's ttwo years without burning. The Neos are a different story with 3500 watts i burned them on music......
12 Volts Baby!!!!
Team Stetsom USA
Team Stinger
Team RENOTS
Db-Drag World Finalist 05,06,08,09
Maryland State Record Holder 05,06,07,08,09
2009 Certified Score 161.0 Db-Drag SS 1-2
NSPL Maryland State Record 06,07,08,09
443-623-4952
For a short time I had a Stetsom 10kd on a 9515E paper cone CF dustcap D1.5 - so probably getting 6kw+++
It loved it as long as I didn't clip it...
10.x volts fo' life!
You will be just fine with around 3k daily on that sub.. as long as you sets the gains correctly, make sure u have no clipping and have sum restraint with volume control you should be fine.
Btw I've seen 9500s take 4-6kw daily in very very select setups and they were run by some experienced competitors with a ton of time on the 9500s. Also they were on the kevlar cones w/ an extremely stiff suspension. I would never suggest running 5k daily to any woofer though, even though after imp rise it will never seen that much power. A "true" 5k after rise will do sum damage to just about any woofer for daily purposes.
Pioneer AVIC-N2
i know this is off subject i know u can get custom made subs and all but u can get damn near every lil detail on the subwoofer custom to ur likings thats pretty cool. i knew about the dust caps magnets and the cones . im sure u would have to call that in though righht?
It will take it fine, go nuts :)
1994 Suzuki Vitara (Escudo)
[unreveiled Subwoofers] - 1,500Wrms, triple stack motor. 15" x 2
DD M1A x 2
10.5 cubes in a tiny car ;)
  • Who's Online   0 Members, 0 Anonymous, 2295 Guests (See full list)
