Ben Building Posted November 3, 2009 Report Share Posted November 3, 2009 It is all in the enclosure. How much space do you have to play with? Link to comment Share on other sites More sharing options...
Forevrbumpn Posted November 3, 2009 Report Share Posted November 3, 2009 on high excursion subs, you usually want to do small area ports, but yeah, even that port is to small, but doesnt look 3"x3" I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy. Link to comment Share on other sites More sharing options...
Macfadyen732 Posted November 3, 2009 Report Share Posted November 3, 2009 Here is the box design before i talked to an orion dealer. what program is that? 2009 Hyundai Accent GL Alpine CDA 9884 Rockford Fosgate Wire Rockford Fosgate 501bd Soundstream 12 Reference Hifonics Zeus ZXI 6410 Rockford Fosgate T1652 Rockford Fosgate T152 XBL: NW Livin Loud Link to comment Share on other sites More sharing options...
Forevrbumpn Posted November 3, 2009 Report Share Posted November 3, 2009 Sketchup I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy. Link to comment Share on other sites More sharing options...
barros57 Posted November 4, 2009 Author Report Share Posted November 4, 2009 Is that box 1.2 cubes before or after sub displacement, the box looks pretty small. 1.2 cubes taking the port area, aub displacement, 1" mdf into acount. My 93 chevy truck Orion HCCA 15's Build 6K HID's 2 orion HCCA 15.4 2 AP30001D's 2 optima yellowtops, 2 C&D 270fr's, all 3 tsunami 1/0, CS144 190 amp Rockford p200-2 Rockford p200-2 Rockford p300-1 Kole KX1 5500D -broken Link to comment Share on other sites More sharing options...
barros57 Posted November 4, 2009 Author Report Share Posted November 4, 2009 you do have to remember that the 10 is a3in coil vs the 4in 12-15 but yes orion says they blow in big boxes my shop crx has 2 hcca 15's in 8.7 cubes after disp. it gets fairly loud on 4k clamped burped a 156.7 on tuff ac mic not a tl i know but still strong we did apair of 10 in a spec box a did a 146.x but you could tell it had a lot left that port they give you is a jokeThe box you have and the one in that sketchup are both way, way, way off. Sorry to be so brutal but that's how it is. It's better to be honest than to let the OP see the magic spoke in the near future if he doesn't fix the enclosure. Thank you for the warning. I will take the sub out and start over. I still have plenty of 1" mdf. Would anyone on here be willing to help me out? Im pretty new at this and i was just trying to follow the specs.. Would a port that bends around the corner of the box work better? What should the box internal CU ft be and what port area and cu ft? My 93 chevy truck Orion HCCA 15's Build 6K HID's 2 orion HCCA 15.4 2 AP30001D's 2 optima yellowtops, 2 C&D 270fr's, all 3 tsunami 1/0, CS144 190 amp Rockford p200-2 Rockford p200-2 Rockford p300-1 Kole KX1 5500D -broken Link to comment Share on other sites More sharing options...
