Headroom?
Dan208
I was wondering if there is a general guidline when it comes to headroom when chosing subs and amps? I'm sure it depends on the quality of the equipment used (such as Boss vs Sundown, etc.), but is there a "safe" number as far as how many watts over the RMS you can/should go on a good quality sub?
it totally depends on the sub. There is no special number at all. Im not even going to try and answer lol....
ask about a specific sub and im sure someone can tell you how much they can really handle.
for example...BTLs can run 2-3k over rms.....
its totally dependent on the sub you're talking about...enclosure design helps too.....
EDIT: for short im saying theres too many variables (even ones i didnt mention) to determine any kind of number.
Eclipse cd7000
NO... You answered your own question already, it's very dependent on the products that you're using(sub(s) + amps). But to avoid voiding any sort of manufacturer's warranty you need to stick by the RMS, regardless of how conservative it may be. They only make it that certain amount of power for a reason.
/thread
Pioneer AVIC-N2
If you have the chance, get a 1ohm solid stable amp that puts out the power you want at 2 or 4,, that is amp Head room.
2007 Great Wall So Cool
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
3-Mechman 250 amp Rhino's
Like the RF T1500-1BD. 1793 watts x 1 @ 1 ohm, 1217 watts x 1 @ 2 ohms & 735 watts x 1 @ 4 ohms. I never run it at 1 ohm.
  • Who's Online   0 Members, 0 Anonymous, 671 Guests (See full list)
