So I re adjusted my amp better, and now when the bass goes to hit the cd skips and I lose the words untill I back down on the volume or bass knob?
What gives ??
144+ DB'S OUT OF A CONVERTIBLE
12" Funky Pup Subwoofer (The worlds most powerful subwoofer)
6" Aero Ported Box
Hifonics - Bxi2010-D
Pioneer Deck
RD Audio - Front Speaker
Rockford Fosgate - Rear Speakers
KnuKonceptz - 0 Gauge Wire
KnuKonceptz SS Karma - 10 Gauge Sub Wire
KnuKonceptz - Krystal Kable Rca
Big 3 - Upgrade - 0 Gauge
Kinetik - Hc1800 Battery
just as your saying. the cd skips there is really no resolving that what kind of headunit are you running? if you get a ipod you wouldent have that prob ever again. or get an alpine :) just to test my alpine hit it while the music was playing and it wont skip no matter what i do
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
I have a pioneer like a few yrs old, but I have had a few other brands, and this unit seems to get my system the loudest and sounds better.
I was thinking of instead of bolting the cd player directly to the car with its frame that holds the deck, I would put some think rubber grommets in between them
to break down the vibration ..
or just losing the screws a little to help
idk. any other ideals
6" Aero Ported Box
Pioneer Deck
best anti-skip products, flash drives or an ipod.
QUOTE FOR TRUTH!! I too have a HU that skips if you just look at it LOL! (Older model panasonic) As soon as I switched my tunes to a Ipod, problem solved 100%
I love my staffie :good:
So anti FACEBOOK it isn't even funny
Don't most newer HUs have anti-ship that read like 30 seconds ahead of the actual output?
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
By what he's saying sounds like to much voltage drop he losses vocals un till he turns it down voltage drop in a lot of decks will cause skipping as well
haha thats even worse than what i thought HO alt FTW!!
Build in Progress
T3 Audio T2000 12
ARC SE4000
DC power 270xp
my youtube channel
x2, i think its because of voltage drops
Alpine 9886
Polk Audio 6.5 Component db series
Elemental Designs nine.4
JL Audio 1000/1
DC Lvl 4 15" - 3.95 cu ft/tuned to 32 hz
Clarion EQS746
Stinger Voltage Meter
Optima Yellow Top (Front)
XS Power 1200 (Rear)
All KnuKonceptz Wiring
So you still hear the Bass but the Vocals Mess Up? Are your door speakers ran off of the HU?
I had a problem a few months back, The rear by 9's were not hooked up, and when the bass it the vocals would just stop or sometimes make kinda a crackling sound in and out. First I thought it was the HU skipping but it wasnt that, then I thought maybe the harness was loose in the back of the HU it wasnt that, Well Eventually it turned out it was the leads going to the by 9's, there was a small bit of wire protruding from the pos. lead going to the by 9, well it turns out when the bass hit it would cause the wire to hit the rear deck metal and ground out, therefore causing my vocals to cut in and out, so I taped up the wire better and problem gone.
So it you happen to not have a set of speakers connected and the leads are loose I would check to make sure they arent grounding out.
Thats my lil story LOL.
¿ǝɯɐƃ ǝɥʇ
