GRRR!!! amp fried from broken cd parts. WTF!
barros57
Used Kicker ZX2500.1 if you can find one floating around the forums or ebay... If u wanna stay with cheaper amps then the AP30001 will do its power at 2ohms.
Pioneer AVIC-N2
I will look into that.
http://cgi.ebay.com/3000-WATT-AUDIOPIPE-MO...=item518c48e40f
should I buy the GD-6001 or the AP-30001D?
Im reading that the 30001D actually does 2k rms ar 2 ohm!
My 93 chevy truck Orion HCCA 15's Build
6K HID's
2 orion HCCA 15.4
2 AP30001D's
2 optima yellowtops, 2 C&D 270fr's, all 3 tsunami 1/0, CS144 190 amp
Rockford p200-2
Rockford p200-2
Rockford p300-1
Kole KX1 5500D -broken
no it does 3K at 2ohms
every website puts the power it does down wrong
2000X1 at 4 ohm
3000X1 at 2 ohm
XXXX x1 at 1 ohm ( i have ran the amp at 1ohm but sucks lots of power other have also done it)
500x2 at 4 ohm
1000x2 at 2 ohm
1500x2 at 1 ohm
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
2000X1 at 4 ohm
3000X1 at 2 ohm
500x2 at 4 ohm
1000x2 at 2 ohm
1500x2 at 1 ohm
Will the orion even handle that power?
I will need to upgrade my alt. I have a 105 anp stock GM and 0 gauge big 3
6K HID's
2 orion HCCA 15.4
2 AP30001D's
Rockford p200-2
Rockford p200-2
Rockford p300-1
2000X1 at 4 ohm
3000X1 at 2 ohm
500x2 at 4 ohm
1000x2 at 2 ohm
1500x2 at 1 ohm
6K HID's
2 orion HCCA 15.4
2 AP30001D's
Rockford p200-2
Rockford p200-2
Rockford p300-1
i bet your 15" orion will take it pretty easily, its what i plan on doing in the future (2500-3000wrms on 15 HCCA).. and yesh definitely upgrade that alt!!
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
dont be stupid and it will handle it no problem
ive got a 140A alt and 2 red tops in the back 2 runs of 1 gauge and im running 2 AP30001Ds mind you it cant play full tilt very long
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
  • Who's Online   0 Members, 0 Anonymous, 838 Guests (See full list)
