Okay..I have 2 Alpine type R 12s and an alpine mrp-m1000 amp..I was driving home today and it worked just fine then after about an hour i started my car and it didnt work at all..The amp still has the blue light on it to say that its on but there is no sound coming out of the subs..Yes they are hooked up. Does anyone know what might have happened
http://www.youtube.c...er/SmallTownSPL
2002 Chevy Blazer
Substage: Shhh, its a secret ;)
Mids and Highs: Stock-Going to change soon
Amp:MTX 92001
Wire:1/0 Welding cable
Electrical:Stock
http://www.stevemead...__fromsearch__1
I hope she was meaning that to you. Any who.... You dont say you wanna have dinner in the first damn post. talk to her first. I say find out if the status was torwards you..
Here try this...
"Hey hows it going :)( notice smiley face makes everything better ) I saw your status. "You are far from usual".... So is my dick... Wanna Fuck tommorow???"
Or send her message saying "hey" she replies back "hey" when this happens reply Wanna fuck (INSERT ADDRESS HERE)
Quote of the SPL Creed ; back in the day my girlfriend gave me a choice between her and my love for car audio, I told that bitch I've made harder decisions at the Coke machine. :)
rcas come loose? pinched?
I dont think so..I checked them on the amp and they were fine and i dont think they are pinched anywhere
2002 Chevy Blazer
Amp:MTX 92001
Electrical:Stock
Here try this...
amp hot to the touch when it went off?
my wifes MRP500 randomly turned off the other day and we werent even bumping on it hard at all. turned car off and back on and she came right back on. scenario was just like yours too.
blue light is in the good...check the rcas from the head unit and at the amp. check wires going to the sub on both sides.
Eclipse cd7000
check amp ground, RCA's hooked up on the amp and on the back of the headunit. make sure the rca's arent pinched ANYWHERE along the line from the headunit to the amp. check the speaker connections. make sure theyre plugged into the sub (stupid but its happened many times)
Everything is connected..I think..maybe not to the radio ill have to check
2002 Chevy Blazer
Amp:MTX 92001
Electrical:Stock
Here try this...
I think I may know what happened..What would happen if you wire an amp that isn't one ohm stable at one ohm??? I just learned that mine are wired at 1 ohm and my amp is not one ohm stable
2002 Chevy Blazer
Amp:MTX 92001
Electrical:Stock
Here try this...
i dont think anyone said this yet. check with a multimeter and set it to Ohms and put it to each of your subwoofers. check each coil (you have 2 on each sub) and make sure they read within 2 ohms or 4 ohms (2 different models for type r's)
There 2 ohm subs
2002 Chevy Blazer
Amp:MTX 92001
Electrical:Stock
Here try this...
