They all do the same thing. As long as it's done right. Cost? I did my Expedition top and bottom to much $ for Dynomat. I will shop next time. Heat gun and a Roller and lot of time. Took me about two weeks for my truck. Taking all the car apart and applying, re-installing interior.
Alpine D900 head unit 7" flip out t.v
Kicker 6 1/2 components (front,rear)KS 6502
MB quart 3 1/2" in front A/C vent's (center channel)
DC Audio LVL 5 18" (pair) Custom ported box
Sundown 4500 at .5
Sundown 100.4
XS 3100 up front and a pair of XS 6500 in the rear.
1 17" Eiger Vision T.V
2 7" Eiger Vision T.V in Second row.
Dynomat Top to Bottom (foam in all halo beam's)
DC Eng Alt 260SP and a 400SP dual set up.
big 3
Sitting on 24"
If your neighbor don't complain it's not Loud!
So you best go fix your shit !!!!!!!!!!!!!!
Do you personally have experience working with all three companies? There IS a difference I have used all three and a couple others and there is a difference in what the outcome will be. You defiantly get what you pay for! I will only use Second Skin From now on!
Ok what are they? I have used Dyno and Sch. Dyno was a lot more expensive and the application was hard.
Sundown 4500 at .5
Sundown 100.4
big 3
Sitting on 24"
I've played around with everything from SS to Dynamat to Peel and Seal... The single best product I've used is Second Skin Damp Pro.
Pioneer AVIC-N2
